Old 12-25-2016, 03:55 PM   #15
2011 30' Flying Cloud
Greenback , Tennessee
Get or make yourself a checklist to use when you are setting up camp and, especially, before departure. Put everything on the checklist and use it every time. When you are new to this stuff, there are so many things that need be done that it's easy to miss something critical.
Gneiss Guy is offline   Reply With Quote
Old 12-25-2016, 04:24 PM   #16
jcl
Vancouver , British Columbia
Originally Posted by AWCHIEF View Post
"The best advice I got was "Start the trailer where you want it to go and follow it"."
I have heard that. I still have no idea what it means.
It is how you back around a corner. When reversing, and relatively straight, turn the steering left (left hand down), to start the trailer going right. Once the trailer is going right, you steer right (right hand down) to keep it going right, ie you follow it around.
Jeff
jcl is offline   Reply With Quote
Old 12-25-2016, 04:55 PM   #17
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Spinnaker John after 30 years of backing up you might trying driving forward <g>
That is where making small corrections comes in. If the corrections are done right you will find yourself suddenly following the trailer. It feels good when it happens, almost a Zen moment.
Mattirs is offline   Reply With Quote
Old 12-25-2016, 05:13 PM   #18
2001 30' Classic S/O
Marshall Ford , Texas
Mattirs,
Good one.
Small corrections and lots of practice with no one looking!
Spinakerjohn
TexAirS is offline   Reply With Quote
Old 12-25-2016, 07:17 PM   #19
2014 27' Flying Cloud
Stowe , Vermont
I have quite a comprehensive packing list. If you are interested in a copy, contact me at: sgraner@aol.com
VT Wanderer is offline   Reply With Quote
Old 12-26-2016, 07:55 AM   #20
Box Elder (formerly of Center Moriches, NY) , South Dakota
Welcome, Diocletian! Do yourselves a HUGE favor. Find and attend an RV Boot Camp. In RVBC you, along with about 200 other newbies, will get a GREAT education in a short period of time. The Escapees run a wonderful RVBC, usually over a weekend. IN RVBC, all the the systems found on a modern RV will be explained and demystified. Towing, tires (and much more) are well covered too. Some insurance companies offer discounts to RVBC graduates. Other groups offer versions of RVBC too (RVSEF and RV-Dreams quickly come to mind). Mistakes made with RVs are often expensive and, sometimes dangerous. RVBC graduates are safer, better informed RVers (and smarter RV buyers). You've also found a GREAT forum. Knowledgeable folks here who are very generous in helping other RVers. Again, WELCOME!
NY24 is offline   Reply With Quote
Old 12-27-2016, 05:21 AM   #21
Captain Hank's Avatar
2007 27' Safari FB SE
Summerville , South Carolina
You can also join the Wally Byam Airstream Club (http://wbcci.org/). Affiliate with a local Unit and you will find experienced Airstreamer's willing to help you answer your questions.
Plus you will have fine group of people to camp with.
Captain Hank is offline   Reply With Quote
Old 12-27-2016, 07:37 PM   #22
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
CHECKLIST, CHECKLIST, CHECKLIST!
One to load the trailer, one BEFORE you move off, one to set up, one to break camp.
Get used to it; the dynamics of using the RV will tell you what you need to write down. Use them and you will generally stay out of trouble.
If it's good enough for Aviators, it's good enough for us.
Trailer Trash waiting for Spring.
MelGoddard is offline   Reply With Quote
Old 12-28-2016, 05:09 AM   #23
Naper's Avatar
Loretto , Ontario
We were all newbies once and all have stories to now laugh about. There is nothing that you can do that hasn't happened to others.
Best advice I can give is enjoy the adventure.
Naper is offline   Reply With Quote
Old 12-28-2016, 02:13 PM   #24
Diocletian's Avatar
Seattle , Washington
If the new Jeep does not come with a factory installed brake control you will need one. It should be plug and play. Wiring harnesses/connection is located under the dash close to the steering wheel.
Thanks Michael. We just got our new Jeep today, and the dealer told us that Jeep does not make a trailer brake assist so we will need to get an after-market one. Do you have any suggestions? I was not even aware there was such a thing until I read your post - so thank you! :-)
Diocletian is offline   Reply With Quote
Old 12-28-2016, 02:55 PM   #25
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
Newbie Advice (Tow Hitch/Towing/Other Essentials)?
When I bought my AS, the dealer also sold me and installed the weight distribution hitch and trailer brake controller. They have worked fine ever since. While there are no doubt other alternatives I could have considered, I didn't know any more than you did at the time, and so probably could not have made an intelligent choice. Also, getting everything from one place meant there was only one place I needed to go to get everything explained, repaired, and replaced if necessary, which thankfully it wasn't. Hopefully it also meant that the dealer, at least, thought it was all compatible with my new trailer.
McDave is offline   Reply With Quote
Old 01-16-2017, 09:24 AM   #26
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
More than once, we get out the smartphone, set the map to satellite, and look at the store, gas station, etc, in advance of arrival. This allows some advance planning for getting in, as well as an exit strategy.....
Tom
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 01-16-2017, 10:19 AM   #27
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Tom
This. It's important to know how you and your trailer will exit a parking lot or fuel station before you pull in. With the base camp, you have more leeway than with a 30 footer, but still you'll want to know you can get out easily before pulling in.
Mike
Caffeinated is offline   Reply With Quote
Transmission Cooler Essentials mstephens Tow Vehicles 41 02-03-2015 05:48 PM
Airstream's List of Essentials. Are they? clicknathan Full-Timing 34 09-13-2013 08:06 AM
LED technology essentials Excellin Lights - Interior & Exterior 10 01-30-2012 10:25 AM
Top 10 Essentials for Road Trip boutdoors On The Road... 41 03-10-2010 08:03 AM
