Old 06-24-2014, 07:26 PM   #43
2010 28' Flying Cloud
Slidell , Louisiana
We use inexpensive WearEver stainless steel cookwear available at Wal-Mart. Just take a magnet with you, if it sticks, it will work on an induction coktop. Our cooktop is a Max Burton (about $75 from Amazon)
dayner is offline   Reply With Quote
Old 07-01-2014, 04:01 AM   #44
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
Thank you so much - this is very helpful!
Rhino33 is offline   Reply With Quote
Old 08-19-2017, 09:56 PM   #45
2018 25' Flying Cloud
Topeka , Kansas
Originally Posted by RoadKingMoe View Post
The first thing you need to get is some Walbernize and wax the trailer. A quart will do a 34'.
You shouldn't NEED this on a new trailer, but if you find gaps in the caulking around windows, etc., the caulk the factory uses is Sika-Flex 221 Gray. I don't know where you find it in single tube quantities, besides the Airstream factory store, where I got mine. Don't be surprised if you do need to fix caulking gaps, and that you can lay a bead nicer than the factory does.
I know the rest here isn't really a shopping list, but it's good advice for every new owner from a former RV tech. Regardless of who does your delivery, do these things YOURSELF:
Check the lug nuts torque and tire pressures! Go back 100 miles or so later and check torque again.
Soap test all LP fittings you can find, in and under the trailer!
While under there, look for any gaps mice could get in (i.e. bigger than your little finger), and seal them with caulk, aluminum wool, or strips of aluminum screening. Don't try to seal every seam. You AREN'T going to stop ants, and you need places for water to escape n the event of a leak.
Run plenty of water in each sink, shower, and toilet, and look in every nook and cranny for evidence of water or drain pipe joint leaks! Check both with city water hooked up and water from the fresh tank.
Make sure there's no AC or DC current to ground when the trailer is plugged in (multimeter set on AC and DC milliamps, one lead on trailer bare metal, the other in the ground).
Use a circuit tester in every electrical outlet to make sure it's wired correctly!
Check all 12V lighter plugs for power and proper polarity.
Check all gas appliances for proper operation (make sure there's water in the water heater before testing it), including refrigerator on gas.
Check the Winegard antenna, both antenna connections, and all electrical appliances, fans, and lights, for proper function.
Make sure all windows and compartment locks function properly. Clean sticking window gaskets and coat with silicone spray.
Open the gravel guards on each side, and make sure they swing freely. Same with the solar guards over the front windows.
Others may remember things I've forgotten.
This such an informative list. It will help us be safer! Getting closer! Thanks so much!
Topeka is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 08:56 AM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
