Old 10-14-2014, 05:29 PM   #1
2014 27' Flying Cloud
Seguin , Texas
New Owner questions
Taking our new 2014 FC 27'
ready for Maiden voyage this Thursday. Just plugged the power in for the first time to start cooling down the fridge and charge the batteries.
What temp setting do most people use on the fridge? (1 thru 5)?
How long does it typically take for fridge to cool down to temperature?
Does the Parallax Power Converter fan cut on when the batteries are being charged? It's cycling on and off.
Thanks for help?
Mark
Laidback1 is offline   Reply With Quote
Old 10-14-2014, 06:28 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
The converter fan cycling on/off is normal whenever you are connected to shore power (even if your use/store switch is set to store).
I've been leaving my frig on 1. It will read 31 degrees on the frig screen, but I don't think it's actually that cold in the frig (based on a separate thermometer I keep in the frig).
If I have a couple of weeks between trips I'll leave the frig on, but I turn the temp setting up to 3 or 4 with jugs of water inside.
Landrum is offline   Reply With Quote
Old 10-14-2014, 06:49 PM   #3
2008 27' Safari FB SE
Pfafftown , North Carolina
The refrigerator in our trailer normally takes at least 12 hours to cool completely down. I keep the thermostat on "4" unless we are in extremely hot weather and then I move the thermostat to "5". Keeping the thermostat on "4" generally results in a reading of 36 degrees on the display.
Hope this helps. Good luck with your new trailer. We love our 27FB.
Susan
sunnygirl is offline   Reply With Quote
Old 10-14-2014, 06:53 PM   #4
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Taking delivery of a 30' Flying Cloud and as I was wandering around I could not find the fan that is outside the trailer. I was told that the larger models do not have a refrigerator fan. Can others confirm this?
TinCan
graysailor is offline   Reply With Quote
Old 10-14-2014, 07:13 PM   #5
Seguin , Texas
Thanks!
New owner new project lots of questions Dustycowgirl 1968 Overlander 14 08-12-2014 07:10 PM
NEW OWNER of One Owner 1972 Ambassador 29 foot Mrwaterway Member Introductions 11 11-20-2009 12:53 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
New AS owner with questions Zmod Our Community 11 12-03-2003 05:25 PM
Questions from a new A/S owner. Help. bluvalley Hitches, Couplers & Balls 6 10-30-2003 10:58 PM
