Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-16-2002, 10:33 PM   #1
Profile:
Talking new airstreamer
I just bought an airstream 1960, 26', land yatch.
My brain is filled with question marks. The furnitures are great but I can't figure out where to begin for the electrical system and the water and the gas. I don't know what is working and what's not. I don't know what's missing.
How to change things and repair, how to check everything so it's safe (gas).
Should I go solar? Is there small wooden stove for heat ? many more questions.
Is there a manual for all those questions? where could I find the original manual so I can figure out where are the wires and tubes ect...
Where can I find
I hope I did make some sens. This is all very exiting but very confusing.
ced
halloey is offline   Reply With Quote
Old 06-16-2002, 11:15 PM   #2
Profile:
If I am not mistaken, I believe you can order a manual for your trailer through Airstream - check out their website at www.Airstream.com.
I, too, knew NOTHING about Airstreams, let alone any RV when I purchased my motorhome. It is currently with a mechanic who is going over all the mechanicals (engine, alternator, carbuerator, etc.) before turning it over to some of his buddies at Traveland in Irvine, CA to go over all the systems (water, electrical, gas, etc.) and to make sure all the appliances work and there are no leaks (in the gas or plumbing).
Welcome to the family!
-Emily
eraffety is offline   Reply With Quote
Old 06-17-2002, 05:06 AM   #3
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Owners and Service Manuals
Start Here. You won't get a Service Manual for this old of a unit, but you should be able to get a User Manual:
Helen Davis Secretarial Services
PO Box 484
Sidney, OH 45365
(937) 492-8885
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 06-17-2002, 10:39 AM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
check for gas leaks
The easiest way to check for propane leaks is to mix some dish soap with water. Turn the gas on and brush the soap on the line, starting at the LP tank connection and work your way thru the trailer one section at a time.
If it bubbles up, there is a leak. Teflon tape on the threads will usually fix a leaky connection.
As for other things, many helpful hints can be found by searching thru the forums. If you have a question about a specific item such as the electric brakes, click the "Search" button and type "brakes" as the keyword.
Good luck.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Pingbacks are On
Airstreamer "Meetups" rluhr Our Community 20 07-17-2004 06:12 AM
petite airstreamer nettepdx Buyer Guidelines 15 10-31-2003 12:10 PM
Finally an Airstreamer 62 Overlander Our Community 10 01-27-2003 03:00 PM
Regulations in Germany for Airstreamer Hagen Our Community 16 12-24-2002 01:26 PM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
