Old 10-05-2018, 09:54 PM   #1
2018 27' International
Manakin Sabot , Virginia
Netflix?
We just purchased the airstream international serenity 27FB. When we went through our walk-through of the gentleman pulled up Netflix. With two little ones we would like to be able to find this feature again. Iíve read through the manuals and Iíve played around with the TV for hours. Can anyone help me locate the Netflix icon?
Ours has the CLARiON system, Blu-ray player and Samsung TV.
CarltonFAM is offline   Reply With Quote
Old 10-05-2018, 10:12 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Netflix is an app on your DVD player.
Turn on the TV, select HDMI source. Turn on the DVD player. Using the DVD player remote you can navigate to netflix.
You will need to connect the DVD player to a wireless network to make it work.
Personally, I use an Apple TV to get Netflix and other online content.
Good luck!
wulfraat is offline   Reply With Quote
Old 10-06-2018, 07:55 PM   #3
Thank you so much!! I found it!! I’m trying to set up the Internet through Settings. The only option I have is to hardwire the internet? How do you get around this?
Old 10-06-2018, 08:07 PM   #4
wulfraat's Avatar
Netflix?
Unfortunate, yes, the Samsung DVD player requires a wired Ethernet connection.
I donít use it, rather, I use an Apple TV.
To get internet to the DVD player, at a minimum you will need to buy a WiFi router, that has WiFi-wan capabilities.
I use a pepwave soho, and recommend it.
Old 11-07-2018, 06:39 PM   #5
1992 21' Sovereign
Denton , Texas
I replaced the DVD player with the similar model that had wifi. I can get Netflix using a cell phone hotspot.
Brad-TX is offline   Reply With Quote
Old 11-07-2018, 07:02 PM   #6
2017 23' International
hendersonville , North Carolina
Netflix
On our 2017 23D we just stuck a "Firestick" into the TV. It is an Amazon product. Takes about 10 minutes to set up. Wherever your staying, if they have WIFI, you can get Netflix. Works great. About $40.00. I am sure there are other solutions but this works well for us.
uraljohn is offline   Reply With Quote
Old 12-14-2018, 09:45 AM   #7
2018 30' Classic
Jacksonville , Florida
Streaming movies on the park WIFI...ÖÖ. that's why park WIFIs are so pitiful. They are over loaded.
Overstreet is offline   Reply With Quote
Old 12-14-2018, 12:59 PM   #8
Netflix at RV parks
We are always careful with our Netflix use. We always ask ahead of time if we are allowed to stream Netflix. We are currently at Land Yacht Harbor in Melbourne, Florida for the winter. Yes, they have WIFI at the recreation hall only. So we had Charter Spectrum install Internet and cable TV in our AS. Not everyone is as rude as you imply.
We stayed at TOP of Georgia (Airstream Park) last summer and had no problem with Netflix. The park has very good WIFI.
Old 12-14-2018, 02:09 PM   #9
2015 30' Classic
Pleasanton , California
The Apps are found on the Samsung TV. Here's a link that should help you get going.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 12-14-2018, 05:16 PM   #10
2017 28' International
Baileys Harbor , Wisconsin
We use our smartphone as hotspot modems and run Netflix on our Roku. Don’t try and use the campsite Wifi. They are generally terrible and will not work well. My suggestion is get a weboost for your cell phone to get better signal, get an unlimited data plan on cell, and use that. And if you are traveling a lot you may want to consider satellite systems for internet or a dedicated wifi modem wireless data plan.
Also if you get a ROKU or APPLE TV you have a host of other viewing options. Happy Camping.
Daquenzer is offline   Reply With Quote
Old 12-14-2018, 06:14 PM   #11
wulfraat's Avatar
Netflix?
They are not overloaded, rather, they are under provisioned because parks do not pay the $$$ necessary for high bandwidth connection end to end to your radio device.
I have 1 gigabit service at home. In my house I can stream 1,666 Netflix sessions simultaneously at standard definition.
Parks donít have the revenue to cover the overhead of a proper WiFi network, so you get what you get with old 2.4ghz channels, towers that are too far away, low quality antennas, limited radio channels, channel bandwidth restrictions, and most importantly a pipe from the brick & mortar-housed modem to the internet that is too small.
Itís not that streaming Netflix uses a lot of bandwidth.
Heck - on LTE cell phone hotspot you can stream between 10 and 20 simultaneous standard definition Netflix sessions with 3 or 4 bars of coverage.......
Iíve totally given up on parks WiFi. They are useless. I use LTE cellular internet exclusively. Rarely do I not get 5-15Mbps of bandwidth with my Sure Call antenna and weboost 50db gain powered replicator.....
Old 12-14-2018, 07:39 PM   #12
2007 27' Safari FB SE
Forest Grove , Oregon
Parks don’t have the revenue to cover the overhead of a proper WiFi network, so you get what you get with old 2.4ghz channels, towers that are too far away, low quality antennas, limited radio channels, channel bandwidth restrictions, and most importantly a pipe from the brick & mortar-housed modem to the internet that is too small.
It’s not that streaming Netflix uses a lot of bandwidth.
I’ve totally given up on parks WiFi. They are useless. I use LTE cellular internet exclusively. Rarely do I not get 5-15Mbps of bandwidth with my Sure Call antenna and weboost 50db gain powered replicator.....
Imo it is about gotta pay to play. One must be willing to pay the bucks for amenities. I just checked and Tiger Run in Breckenridge is running $70 plus a night depending on the site location and season. I have been there (no choice as my kid rode the Breck Epic) and they have the wifi service to support what you want to do. So good wifi does exist, just have to be willing to pay the price of entry to get it.
So you pay the price of entry at the campground or determine cost benefit and pay the price doing your own system. Gets back to the notion of no such thing as a free lunch, or you get what you pay for, etc.
bweybright is offline   Reply With Quote
Old 12-14-2018, 10:26 PM   #13
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Save streaming Netflix for home.
Bring dvd’s To the RV Park .
Or pay to play .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 12-14-2018, 11:11 PM   #14
You can also download at home Netflix shows to your IPAD or other devise. Then connect to TV. Way faster and cheaper. And you donít use up data.
Internet Connectivity for Netflix TedandPam Electronics & Connectivity 30 10-16-2018 04:06 PM
2017 25' tv Netflix connect, etc. dlec123 Our Community 20 05-26-2018 08:19 AM
Newbie Setup Internet for Netflix sldimond Audio, Video & TV 1 10-21-2015 11:30 PM
Netflix setup k9jackie Sprinter and B-van Forum 5 03-22-2015 04:35 PM
Long, Long, Trialer on DVD/Netflix Kintscher Airstream "In the News" 2 05-01-2006 10:12 PM
