Old 09-14-2008, 11:59 AM   #1
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
Neighbors?????
It has been great getting to meet and know so many wonderful people over this forum but I would also think there are several streamers on here that live near but the connection is never made. So to the question, Does any know if there is a search method that can be used to look up all members in a given state? I would like to find out who on the forum resides in KY, is this possible? How about some help moderators?
63silver
63Silver is offline   Reply With Quote
Old 09-14-2008, 12:12 PM   #2
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
I have also wanted to search members by location. I know there is the map and I know you can scroll through the member's list but if there is a better and easier way I would love to know how to search too.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 09-14-2008, 12:14 PM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
This is an easy one. Go up to the top blue crossbar and select "MEMBERS". Then over to the right just below the top is a "SEARCH" link, select this and go to "ADVANCED SEARCH" and you can select by state, city, type of trailer, by name, etc. Very useful search function. I found all registered '59 and '60 TradeWind owners to add them to the registry I've been working on.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-14-2008, 12:20 PM   #4
Lapeer , Michigan
Thanks Brad!!!
Hey all you Michiganders where have you been that i haven't met you? !!! Wow there is a lot.
Caroljb
photography
Old 09-14-2008, 01:18 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
FF
Hi Brad
Your instruction appear to be quit straight forward however I could not find the results you predicted.
I opened Members List, then selected Search, then selected Advanced Search. This open the normal search box and when I enter a State it produces all threads with that States name in them. It does not provide anything relating to Membership.
Please advise.
Also looks like the Membership Map in the left column no longer work either
2004 Excursion 4x4
Old 09-14-2008, 02:20 PM   #6
Lapeer , Michigan
Hi Howie, are you selecting the "member search" box on the right of the member list blue banner?
ID:	67346   Click image for larger version
Caroljb
photography
Old 09-14-2008, 02:40 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You can also get to the Member Search function by clicking on "Member Search" in the list of links in the column on the left side of the Portal Page.
TB & Greg and Abbey Schnauzer
#3954
Old 09-14-2008, 02:42 PM   #8
HowieE's Avatar
Images: 12
Wheel Interested
Now that works.
2004 Excursion 4x4
Old 09-14-2008, 06:28 PM   #9
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Talking
Hey 63Silver, I believe we met at a trip to Dale Hollow.
94Tri is offline   Reply With Quote
Old 09-14-2008, 06:51 PM   #10
63Silver's Avatar
1963 28' Ambassador
Images: 43
94tri,
Yes, I think we did. I can't believe how many members in Ky but most have not been active for a while. Maybe the two mof us could set up a KY rally in the spring, what do you think?
63silver
Old 09-14-2008, 07:49 PM   #11
digger bear's Avatar
1973 23' Safari
Do you need help with your rally?
Digger Bear
Non impediti ratione cogitationis
digger bear is offline   Reply With Quote
Old 09-14-2008, 08:10 PM   #12
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
wheelinterested
that's pretty good info
Thanks for the tip
Jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 09-14-2008, 08:26 PM   #13
63Silver's Avatar
1963 28' Ambassador
Images: 43
Digger Bear,
I thought it would be a good idea to meet others in our area (KY) that would like to get together for a little fun. What do you think? Find a central location and see who wants to join in? Let me know what you think and it would be great if you want to help!!
63silver
Old 09-14-2008, 08:55 PM   #14
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
We should be there with our silver (and painted) flotilla in the spring! We should be up for a rally then, although probably won't be able to do much in the way of planning, etc. due to just moving in and getting settled and a shop built.
Looking forward to it! We know a couple great Airstreamers in Richmond already.
Susan
Soon to be in the Richmond area
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Now the neighbors really think we're crazy goransons 1965 - 1969 Overlander 7 08-11-2008 01:10 AM
What your neighbors think... 3streams Off Topic Forum 43 02-14-2008 09:24 AM
Exterior Door Knob??? Neighbors overspray? 64 Lawncondo Doors & Locks 3 09-15-2005 10:37 AM
We're looking to buy an airstream from neighbors..... claras Off Topic Forum 2 05-16-2005 08:21 PM
Unreasonable Neighbors Taking Pictures! swebster Airstream Motorhome Forums 59 12-22-2004 09:32 PM
