Old 09-19-2008, 06:27 PM   #1
2006 19' International CCD
Philadelphia , Pennsylvania
Missing Sticker for Jack, Road Side
Hello All,
did some searches but never did see this scenario...
on the curb side of my 19' ccd is a nice jack sticker pointing to the seam in the belly where jacking should be done (but no metal diamond)
on the roadside of my trailer there is no sticker but i see a diamond shaped (2-3" x 2-3") piece of metal aft of the waste disposal lines.
I need to jack the roadside tomorrow at 8am. Is this metal diamond the place?
Thanks!
ericwarren is offline   Reply With Quote
Old 09-19-2008, 07:55 PM   #2
1973 31' Excella 500
Morristown , Tennessee
Not sure where the jacking spots are on the new trailers but in a pinch, I always use the frame. Why are you jacking the trailer?
Joe
Alumin8 is offline   Reply With Quote
Old 09-19-2008, 07:59 PM   #3
want to change the tire...
Old 09-19-2008, 09:24 PM   #4
_
Originally Posted by ericwarren View Post
... Is this metal diamond the place?...
hi eric
does it look basically like THIS pic from hatfield...
http://www.airforums.com/forums/show...0&postcount=11
if it does, then THAT's the spot!
there are more pix in this thread, and more confusion, but the diamond is the SPOT...
http://www.airforums.com/forums/f457...eam-18435.html
be sure the w/d bars are SLACK if the trailer will still be attached to the t.v.
and DO NOT lower the stabilizer jacks, keep them pulled UP away from the ground.
IF NOT attached to the t.v. RAISE the tongue jack a few inches PAST level,
that way, you won't need to jack it up as far to get the tire airborn
loosen the stud nuts, before raising it, or pull the breakaway cable for JUST 1-2 minutes whilel u loosen nuts...
BE SURE TO BLOCK/chok THE OTHERSIDE >>>>>>>>front and back<<<<<<<<
IF you are gonna leave the trail UP a while, put the breakaway pin BACK in the hole, to avoid problems...
go luck with that bubbled tire swap!
cheers
2air'
Old 09-20-2008, 01:40 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Not sure about newer units but with vintage units you can't exactly see where the frame is and the jack can easily slip and poke a hole in the belly pan. Lots of people jack on the fishplate to which the axles are bolted. Another no no is jacking on the axle itself
Old 09-20-2008, 02:16 PM   #6
ok, happy to report all went well!
have two brand new tires. I figured better to be safe than sorry (just replacing one would have made me crazy).
luckily i have a really nice 3.5 ton floor jack that comes in handy. the only problem is it will be too big to just bring with me. I'll look into a bottle jack should i ever have to make a change in the "wild".
Anyone have an idea the lift height requirement to get this single axle tire up enough to change?
thanks!
Old 09-20-2008, 02:28 PM   #7
richinny's Avatar
2011 34' Classic
you missed the perfect time to measure it!
many folks carry a short 4x4 to put under the front jack foot. you can always borrow that for some extra lift.
Ricky
Missing lower washroom panel, side bath '76 31' Sovereign TobyJH 1974 - 1979 Sovereign 2 04-01-2008 11:05 PM
Road Side Window Replacement bm1068 Sprinter and B-van Forum 7 12-14-2007 11:27 PM
Awnings for Road Side and Back (16' CCD) RDM16CCD Awnings 4 05-27-2006 08:13 PM
Right side, middle of the road, or left of center? DreamStream Off Topic Forum 19 03-02-2004 05:51 AM
