Old 10-15-2014, 06:59 PM   #1
1968 30' Sovereign
Algonquin Highland , Ontario
Mice
I know that little filed mice can get in little tiny space but is anyone out there can tell me How can find out where possible are coming in my Airstream?
Just about every week I get a couple in a trap I set
See you Fonzi
fonzivenditt is offline   Reply With Quote
Old 10-15-2014, 07:06 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look for holes in the belly pan.
Look inside the wheel wells
Look inside the frame of the tongue, it makes a nice tunnel for them to get in the belly pan.
If the shore power cable comes out of the trunk. They can walk up it, then get in the trunk.
Check the vent for the refer. If in the floor.
Old 10-15-2014, 07:14 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
A quarter square inch (about 8 mm sq) is all it takes. I had openings in the wheel wells, belly pan, front A frame rail ends, propane lines, rear bumper lid, and I can't remember where else. Closing what openings I can find has helped some. I went from 20 a winter to 2. Now I winter store indoors which eliminated the mice in the trailer.
I don't know if a mouse can climb up the exterior skins? It wouldn't surprise and that would leave the fridge vent a possibility.
I'll bet the majority of us are plagued with mice infestation. I set my traps and run my trap line daily. I pile their little bodies up outside where the hawk can get them.
My advice is to systematically look for small openings from the belt line down. And then close them up. Loose belly pans is a primary mouse entry.
They make a stinky mess out of an Airstream.
David
PS Yeah, I second what TG said above!
Old 10-17-2014, 08:55 AM   #4
1968 30' Sovereign
Thank you for your help!
But honestly I am new at this and I really do not know where or what a belly pan look like I have 1967 30' airstream a picture or location will be nice.
Thank you
Fonzi
Old 10-17-2014, 09:09 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Thank you
Fonzi
Get on your back under the trailer and you will see the belly pan and probably lots of places where the mice can get in. Invest in a pop rivet tool and some aluminum rivets (1/8" size) and be prepared to rivet the heck out of your belly pan. An old trailer such as yours which has not been properly maintained (sounds like the case here) is most likely a Hilton Hotel for mice.
Bob Martel
WBCCI# 5766
Old 10-17-2014, 09:25 AM   #6
2013 28' International
Blairsville , Georgia
Mice
If you have a shore power source--I use a black and decker electronic pest device. Home Depot used to carry them but in my area they stopped. The last one I got from Amazon. Had mice in storage shed, put one of these in and haven't had one since. I keep one in my shop and in the airstream---no mice!
Also stuff steel wool into the frame right behind the hitch ball receiver.
Pmgill is offline   Reply With Quote
Old 10-17-2014, 09:40 AM   #7
1987 25' Sovereign
Oregon , Ohio
Every fall I buy a new box of dryer sheets and put one sheet in every space under cabinets, couches, beds and outside storage compartments that I can find. Then I leave the open box on the kitchen counter at about the middle of the trailer. In ten years of doing this I have not seen a mouse or their nasty little calling cards. The bonus of leaving the open box on the counter is that the trailer always smells fresh and not musty.
msmcv51 is offline   Reply With Quote
Old 10-19-2014, 07:38 PM   #8
Twinke58's Avatar
1958 26' Overlander
Kansas City , Missouri
Cool idea! I'm going to try that.
Twinke58 is offline   Reply With Quote
Old 10-19-2014, 07:43 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I've tried moth balls and dryer sheets to no avail. Minnesota mice are desperate with the approaching winter. A little odor doesn't phase them. I think it's best to plug the holes and run a snap trap line. The neighbor's cat helps too.
David
Old 10-19-2014, 08:13 PM   #10
1987 25' Sovereign
Oregon , Ohio
David
You are probably right, around here when it gets to 10 below, which it rarely does, I have a hard time smelling things outside.
Old 10-19-2014, 08:30 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Minnesota mice use dryer sheets for nesting and eat Irish Spring soap for lunch. Good luck with that.
Doug and Cheryl
Old 10-20-2014, 04:24 PM   #12
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Has anyone used this type of spray foam product to seal any 'mouse-able' gaps (A frame at the front, belly pan edges, wheel wells)?
GREAT STUFF 16 oz. Pestblock Insulating Foam Sealant-11034540 at The Home Depot
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-20-2014, 04:34 PM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Didn't use that exact product but did use a foam to seal areas. Worked ok. My biggest problem has been the bumper storage. The lid doesn't seal on the edges and always got nice in there. I now close a wad of tin foil in those edges when I put it away for the winter.
2012 Dodge Durango Hemi/AWD
Mice, Mice, Mice Jake General Interior Topics 21 12-01-2009 01:09 PM
Mice in older airstreams? David Henderson 1965 - 1969 Overlander 33 09-01-2008 02:41 PM
Mice Problems? apple 1 Our Community 0 01-31-2003 10:17 AM
mice wallybyam Off Topic Forum 2 01-29-2003 12:29 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 11:01 PM
