Old 03-01-2016, 06:12 AM   #29
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Those are some very nice reports of happy campers with handshakers.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-01-2016, 02:17 PM   #30
2000 30' Excella
2014 30' Classic
Princeton , Iowa
If you are comfortable, go for it. I like manuals, they will stand up better. Automatics have came a long way, but pulling an Airstream can be hard on an automatic.
larryglarson is offline   Reply With Quote
Old 03-01-2016, 02:57 PM   #31
2005 30' Classic
Tucson , Arizona
Thanks to everyone who replied. My intent was to make sure that there wasn't anything universally bad or inconvenient about pulling an Airstream with a standard shift. I am firmly convinced that there isn't.
Will test drive the truck today and we'll see what happens.
- Steve
http://www.fulltimeexplorers.com
sdnet01 is offline   Reply With Quote
Old 03-01-2016, 03:23 PM   #32
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
Yep , there is a longstanding saying about slush boxes " automatics "
It's not a question of " if "one of them will leave you walking ,
it's a matter of when
dannydimitt is offline   Reply With Quote
Old 03-01-2016, 04:49 PM   #33
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Great anti theft device. You would be hard pressed to find a young hooligan who would be able to drive it.
Gearheart is offline   Reply With Quote
Old 03-01-2016, 05:14 PM   #34
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If my dodge had a stick, I would hope someone would steal it....
tjdonahoe is online now   Reply With Quote
Old 03-02-2016, 04:11 AM   #35
2000 36' Land Yacht XC Diesel
Fresno , California
My first big boy tow vehicle was a 3500 Dodge dually Cummins powered with a manual transmission...when the dealer told me just start it in 3rd or 4th if I wasn't towing I thought he was kidding...nope. That thing had too much torque honestly....absolutely the most miserable ride on its own...it lived to tow, so if you're going to use your truck as a daily driver, I'd stay away from the 2003 era Dodge 3500's....pretty sure you can pick one up for a song but not sure if your elbow will say it's worth it...
LucasS is offline   Reply With Quote
Old 03-02-2016, 04:30 AM   #36
Vintage Kin
Fort Worth , Texas
Mines an '04. Manual says, effectively, every gear, every time. I'm on original clutch at 210k. The man trans trucks are slower to accelerate.
Yes, the past ten years and more have improved the ride. Hydraulic can bushings, etc.
KONI FSD shocks, developed for ambulances, etc, are an upgrade on 4WD trucks. Same for high end custom shock/spring packages.
Air ride is also available aftermarket.
Old 03-02-2016, 11:12 AM   #37
GCinSC2's Avatar
Originally Posted by LucasS View Post
when the dealer told me just start it in 3rd or 4th if I wasn't towing I thought he was kidding...nope. That thing had too much torque honestly......
That is a recipe for abusing a clutch and wearing out the facings prematurely.
First gear with a load, Second gear if empty. Engine at idle, no additional fuel, smoothly raise the pedal up and that Cummins and the 6 speed will do its job.
Starting in higher gears requires additional clutch slippage to get everything in motion. Slippage creates heat, heat is the number 1 driver controlled enemy of clutch disc facings.
Not to mention the trans isn't happy taking off in higher gears either.
S/OS #001
Old 03-02-2016, 01:15 PM   #38
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
What he said-
Ease out of the clutch before applying fuel to keep the rig from bucking and jumping-
Smooth and fluid is your goal-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-03-2016, 05:40 AM   #39
2005 30' Classic
Tucson , Arizona
I bought a 2008 Dodge Ram 2500HD 4WD, 6-speed. Awesome truck.
It came with an air ride system and brake controller and full towing package, which of course I will need to pull the Airstream.
And yes, I definitely start in 2nd gear and sometimes do a 2nd, 4th, 6th as I'm driving normally. You really don't need every gear when you're not pulling a heavy rig with a truck like this.
Thanks again for all of your help. Much appreciated.
- Steve
Old 03-03-2016, 07:39 AM   #40
Kevin245's Avatar
I towed with manual trans trucks for years and never had an issue. Stop-n-Go traffic was a pain, otherwise no issues for me. As for backing, the ratio for most reverse gears is very low and I seldom had to feather the clutch while backing.
Just my experience.
Eleanor Roosevelt
Old 03-03-2016, 08:55 AM   #41
jump's Avatar
2013 30' International
lubbock , Texas
I like driving stick shifts ... 'Cept I keep dropping my donuts & spilling the coffee
jump is offline   Reply With Quote
Old 03-03-2016, 09:11 AM   #42
Kevin245's Avatar
I use to hang the doughnuts from the shifter. With 3-on-the tree its easy to grab a bite on the up-shift from 1st to 2nd gear. This does not work so well with floor shifters though.
Eleanor Roosevelt
Diesel manual transmission conversion P30? cdufault General Repair Forum 0 01-18-2016 08:29 PM
Airstream 1976 original Service Manual & Owner's Manual, good cond. leong1 Airstream Classifieds 0 11-12-2014 01:44 PM
manual transmission? fozzies Mechanics Corner - Engines, Transmission & More... 2 05-25-2009 05:18 PM
Manual Transmission Versus Automatic mtjim Tow Vehicles 22 12-06-2004 11:49 AM
Dodge manual vs. automatic transmission idahosafari Tow Vehicles 0 02-26-2004 07:52 PM
