11-09-2004, 06:01 PM
2005 25' International CCD
Penn Valley
, The Golden State
Making the bed in the corner...Help!
We took delivery of our beautiful new 25 CCD last week. We're excited about getting out there and using it now. We knew the corner bed would be an issue. It is hard to make in the conventinal way (tucking sheets in, etc.).
My wife has some ideas, and wanted me to "check with the experts" to see how people have solved this problem.
Thanks.
11-09-2004, 06:31 PM
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, Deep East Piney Woods, Texas
One Solution.....
Forum members "MikenLora" bought a 31' Classic.......
11-09-2004, 07:08 PM
418
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills
Thanks.
The Corner bed is alot like one of the gouchos in my Tradewind. My mattress is enclosed on 3 sides, plu sit's heavy foam. I tilt it up and pull a fitted sheet over the reear 2 corners. Then I push it in place, flaten things bu hand and attach the front 2 corners. Your mattress is relatively light, simply lift it forward and tuck the sheets in behind it, then push it back and tuck in the front 2 corners. Done.
No issue at all once you get the technique down.
11-09-2004, 07:17 PM
2005 28' Classic
Austin (Hays County)
Airstream store sheets
I have 2 sets of the sheets sold at the Airstream store. The top and bottom sheets are attached at the foot and there is some velcro at the foot. Even in my trailer where I can get all the way around the bed (tight), I do most bedmaking from the front with these sheets.
I don't know whether they have a set to fit your particular trailer, but I sure like them.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
THLU Webmaster #9632
TAC TX-10
11-09-2004, 09:04 PM
Eastern
Duvet and cover
The simpelist thing I've seen is to use a fitted sheet on the mattress and a comforter with a duvet cover on the top - no top sheet. Peridodically pull off the duvet cover and wash it.
To make the bed you have only to fluff and straighten up the top layer with a quick shake. This is the traditional European thing to do and the trick is to have a duvet cover that is made of high thread count "sheet like" material. Change the pattern seasonaly for variety!
77 Argosy Minuet, 6 metre | 1964 Overlander | '08 Touareg V6
Parts needed: reading light from mid-sixties for restoration project
New signature coming soon ...
11-09-2004, 11:52 PM
2005 28' International CCD
1977 Argosy 22
Western
, Oregon
Try a Travasak
Wildwoodrver,
Similarly, you can purchase a Travasak at http://www.campingworld.com/browse/p...D=3928&src=TSC (shop around on the net for the best price) , which is zippered on both sides, summer and winter sided. Just place this over your mattress pad and you're good to go! The inner lining is a washable sheet, which is velcroed into the sleep system. You just shake it over the bed to fluff it up and there's no need to tuck it in!
It comes in a variety of colors, and looks good with the CCD. We like ours!
Jim & Cheryl
2005 28' CCD
1977 22' Argosy
2004 Chevy Avalanche 2500, 8.1L 4.10 rear axle
Prodigy brake controller/Equalizer hitch
Honda 3000 genset
WBCCI #3538
11-10-2004, 03:18 AM
2004 30' Classic
Field and Stream
, PA & MT
Janet -
I think this is almost exactly the same thing as we do. My wife gets ours from Germany, and we use the same things at home. She also uses form fittng sheets, but as far as the cover, you just shake it a bit to keep its form, and fold it on top of the bed - really easy - even I can do it!
Here at home in the winter - now - we have luxurious, down filled ones on our beds. If we ever camped in the winter, we'd take those with us. The ones we have in our trailer during the summer are lighter weight.
By the way, I looked at your web site - which one in the picture is you?
John
Flyfisher
11-10-2004, 07:47 AM
2003 25' Safari
Eden Prairie
, Family in MN, I work in CO - for now
We have a Safari 25SS with a corner bed. It is a real pain to make the bed - especially since the bathroom wall blocks most of another side, and the closet wall blocks half of the foot end. Our solution is to use sleeping bags, with a fitted sheet on the mattress underneath.
Dan
11-10-2004, 08:40 AM
Although we use the duvets at home, another method would be to put a fitted sheet on and then use the silk sleep sacks, with the duvet on top. The silk washes by hand and dries very fast, so there is no bother with having to wash the heavier covers so much. I've done this for months at a time, when travelling. The silk sack weighs ounces. Magellian's catalogue has them as well as other travel catalogues. Duvet covers are available in the US. I have organic cotton 320 count thread and they are WONDERFUL. Check the organic and green bedding sources on the web. Even "The Company Store" carries regular cotton and a range of down comforter weights. silver suz
11-13-2004, 05:54 AM
Here's another vote for the Travasak. It's basically a big sleeping bag with a set of percale sheets velcro'd inside as a liner. When they get dirty, pull them out and pop them in the washer. One size has more insulation than the other and each side is labelled "summer" and "winter". The zippers go all the way down both sides so you can fold the top completely back to get in.
I just place it on top of the Airstream comforter on the mattress and all you have to do to make the bed is straighten it up in the morning and the bed is made.
11-13-2004, 09:17 AM
Southlake
My simple solution is to just don't make it.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
11-13-2004, 12:25 PM
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern
Originally Posted by flyfisher
Janet -
John
Janet is the one with the long hair.
Peace
Gary
11-16-2004, 12:57 PM
Penn Valley
, The Golden State
Thanks all.....my wife ordered a Hacksack! As always, the forum helps with different ideas and one then is able to make an informed decision. (She wouldn't go along with my vote; "why make the bed?")
We are heading out on our maiden voyage Thursday and hope the Hacksack arrives in time. We'll be heading down to Big Sur, after a stop in the Bay Area for our youngest grandchild's big FIRST birthday.
Again, thanks all.
| Thread Tools |
| Display Modes |
