05-29-2013, 03:10 PM
1995 34' Excella
Dalton
Magic Chef oven pilot lighting
We have a 68 Tradewind with the original Magic Chef oven in excellent condition. While camping over the weekend and the need to use the oven I finally was able to light the pilot and use the oven. I have since learned the oven has 2 pilots, a constant pilot and a heater pilot. My question is...what are the proper steps for lighting the constant pilot on the Magic Chef oven? If I understand correctly some of the info I have read,after the constant pilot is lit it remains on while camping and when you need to use the oven you light the heater pilot with the constant pilot. Thanks in advance for all the help!
Eric & Michelle Shuler
1995 34' Excella
2003 Chevrolet Silverado Z71
WBCCI # 7096
05-29-2013, 03:23 PM
, At Large
From what I remember from our '63, it's pretty basic. Turn the thermotat knob to pilot, push in the knob, hold it in, light the pilot with a suitable flaming device, continue holding he knob in for a minute or so, then turn the knob to the desired temp.
05-29-2013, 03:44 PM
1995 34' Excella
Dalton
Thanks Terry,
I don't remember seeing a pilot position on our thermostat knob,but this was my first time using the oven. I will take another look at it and see if ours has a pilot position. Many Thanks!
1995 34' Excella
WBCCI # 7096
05-29-2013, 03:48 PM
, At Large
Originally Posted by falcon-N-Air
Thanks Terry,
It isn't really clear. I think it says "off" and "pilot off".
05-29-2013, 05:58 PM
1995 34' Excella
Dalton
Thanks Terry!
1995 34' Excella
WBCCI # 7096
05-29-2013, 06:36 PM
1964 19' Globetrotter
South Kingstown
, Rhode Island
If yours is like our '64, there is no "pilot" on the thermostat, the little "constant" pilot will always be on, so you just light it. When you turn the thermostat to the desired temp, the bigger pilot will light, and then the oven burner. There is no thermocouple so the gas will always run to the constant pilot. If you don't keep it lit, you want to turn the gas off to the range or you'll have a constant dribble of gas.
Wherever you go, there you are
05-29-2013, 07:00 PM
Full Time Alumaloafer
1966 24' Tradewind
Livingston
Look for the shutoff valve for the line to the oven constant pilot under the cooktop. It will be the one to the right of the oven knob ( if it is in the center like mine) and may be shut off. I always close this valve when traveling and open it when lighting the pilot. The heater pilot comes on automatically when the oven knob is switched on. You'll need a wide flathead screwdriver to open the valve.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
05-29-2013, 07:07 PM
1974 Argosy 20
Kooskia
, Idaho
This is the drill. Turn the gas valve from "pilot off" to "off". Light the constant pilot. When using the oven, simply turn the oven control to the temp you want and it will light the big pilot and a few moments later the main burner will come on.
When you are not using the oven at all, or when in storage etc. turn the oven control to "pilot off" and all gas flow will stop.
05-29-2013, 07:46 PM
1966 24' Tradewind
Livingston
idroba, where is the switch located for off and pilot off? My Magic Chef only has a master shutoff valve ( oven and cooktop ) and an oven shutoff( the one I referred to.) Just wondering as many items in my rig have been "monkey'd with" prior to my ownership.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
05-29-2013, 08:52 PM
South Kingstown
, Rhode Island
Lou, your trailer may be old enough (like mine) that it doesn't have a "pilot off". It came that way from the factory. You can turn the main valve off under the cooktop. There are screws the control the size of the pilot... ours are on the oven thermostat body. You can look at the tag on the stove, probably under the cooktop near the rear, find out the model number (like "720" or something) and google it. I found our operating manual online.
05-29-2013, 09:08 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
Click on TouringDan, then click on statistics. Find the thread that I wrote on how to light the Magic Chef oven. This should help you.
Dan
05-30-2013, 04:32 AM
1995 34' Excella
Dalton
Thanks guys for all the wonderful info!
1995 34' Excella
WBCCI # 7096
05-30-2013, 06:12 AM
1966 24' Tradewind
Livingston
Globi64, thank you for the info. I believe you are right, as that is the way I have been using the stove/oven. The model number is not legible, but I will research further.
falcon-N-Air, I hope you have success with yours!
TouringDan, Thank you again for providing great info!
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
05-31-2013, 04:05 AM
1995 34' Excella
Dalton
Thanks Lou, going to try and check it out further this weekend. How close are you to Stockbridge,Mass. ?
1995 34' Excella
WBCCI # 7096
05-31-2013, 05:37 AM
1966 24' Tradewind
Livingston
I'm about 45 minutes north, though I'll be heading to Vermont for the weekend.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
05-31-2013, 09:12 AM
1974 Argosy 20
Kooskia
, Idaho
Others are most likely correct, your stove does not have a "pilot off" position on the main oven valve. I forgot that was a later change to Magic Chef ranges. As they have said, there is a valve under the cooktop to turn the gas off to the oven system.
05-31-2013, 02:03 PM
Hendersonville, NC
Magic Chef info from 1968 owner's manual
I retyped this and scanned the figures. Hope this helps.
Pat
magic chef_68_airstreams.pdf
06-01-2013, 01:41 PM
1995 34' Excella
Dalton
Lou,
We flew into Hartford,Ct. and drove to Stockbridge,Mass. several years ago, I think this was one of the most beautiful places I have had the privilege of seeing, loved the Norman Rockwell Museum. I hope to visit Vermont someday.
1995 34' Excella
WBCCI # 7096
06-01-2013, 01:43 PM
1995 34' Excella
Dalton
@ idroba, thank you for all your help!
@ kokopat, I really appreciate the info, many Thanks everyone!!!
1995 34' Excella
WBCCI # 7096
06-02-2013, 05:17 AM
1966 24' Tradewind
Livingston
Falcon-N-Air, if you enjoyed the southern Berkshires, I'd highly recommend a tour through the northern portion of the county and into Vermont, should the opportunity arise. My wife and I will be spending our weekends in Wilmington, VT this summer, and can't say enough about the hospitality as well as the beauty throughout the area. God bless!
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
