Old 12-09-2018, 01:48 PM   #1
2014 27' FB International
Cedar Park , Texas
LP Gas Detector
I have an Airstream 2014 Intl Signature. Last week my LP Gas Detector just quit working: No Light No Noise. The manual mentions a fuse. After calling Airstream Customer Service, they stated there is no fuse in this model. Des anyone have experience in replacing the Detector on this model? If so is there a fuse or not and if there is where is it? Can I replace the device after simply disconnecting the battery connection?
joecesaro is offline   Reply With Quote
Old 12-09-2018, 04:08 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I don't have your model, but both of my trailers have/had a fuse feeding the propane detector. It was an inline fuseholder in the same general vicinity as the 12V distribution panel. You could also look behind the detector at the wiring.
Also, on both of my trailers, the detector was always on, i.e. i was not affected by the STORE/USE (Battery Disconnect) switch.
As an alternative, maybe the detector has failed. Simple test - get a voltmeter and check the power at the detector.
Al
Old 12-28-2018, 07:52 PM   #3
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
It’s interesting that AS would design a electrical system that would NOT be protected by a fuse. The liability of that statement if a electrical fire did happen would be over the top.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 12-28-2018, 11:15 PM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
According to the 2014 International Owners Manual there is a fuse. On page on page E7 under the LP gas detector it says; "Your LP gas detector is wired directly to your vehicle battery and incorporates a 1-amp in-line fuse".
Both of my trailers have an in line fuse included in the wiring directly behind the LP detector.
You can read that manual here>
https://www.airstream.com/wp-content...manual-146.pdf
Alan
Gas & Pollution Detector? 66Overlander 1984 - 1989 Sovereign 6 02-16-2009 07:13 AM
LP gas detector fault mode silverback Electrical - Systems, Generators, Batteries & Solar 6 02-15-2005 06:42 PM
LP gas detector uucal LP Gas, Piping, Tanks & Regulators 0 03-07-2004 08:39 PM
Engine will not start - LP Gas detector? AccessMaster Airstream Motorhome Forums 6 08-31-2003 08:38 AM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
