Old 01-12-2017, 09:29 AM   #1
Baton Rouge , Louisiana
Low water pressure
While on city water, the galley pressure is low but the head faucets are good.
Where to start checking
jcm14246 is offline   Reply With Quote
Old 01-12-2017, 09:45 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
First thing I would check is to look for debris in the aerator screen at the faucet.
If you find it there you should also clean the toilet faucets and shower head screen before they become a problem.
A white/yellow scale builds up inside the water heater, from corrosion and minerals in the water. The kitchen faucet is usually the first place that shows evidence.
The water heater should be drained and flushed at least once per year.
Alan
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Very low water pressure for hot water from pump barrettjl Water Heaters, Filters & Pumps 21 10-27-2014 07:41 AM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
