Old 08-09-2016, 04:22 PM   #1
2001 28' Excella
Chattanooga , 37412
LED's flickering.
Help, replaced all 12 volt lamps with led 12 vdc. They start flickering. Thought it was because of the inverter. Checked it out, everything seems ok, out put voltage is between 13.2 to 14 vdc. At 1 lamp I am getting 13.7 vdc & 38.6 vac??? Don't understand that. Has anyone have a clue what is going on? I have a vintage, 77 model avion.
Anything would help. Thanks in advance.
bgates55 is offline   Reply With Quote
Old 08-09-2016, 04:30 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you have the inverter output connected to the 12 volt system, I could see why the lights are flickering. I'm surprised they haven't blown out from the 120 volt output.
Old 08-09-2016, 07:15 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sounds like you have a very dirt power supply. Try shutting the power supply off and see what happens with just the batteries.
2004 Excursion 4x4
Old 08-10-2016, 02:27 AM   #4
2001 28' Excella
Chattanooga , 37412
With no ac hooked up ,same results. That's what is puzzled me.
Old 08-10-2016, 05:53 AM   #5
1972 27' Overlander
Denver , North Carolina
I'd start at the beginning. Did you do the work yourself, if so did you change any wiring. Most of the 12 volt is daisy chained. Next replace a bulb or two see if it still flickers.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 08-10-2016, 08:14 AM   #6
HowieE's Avatar
Images: 12
I think the choice now is to remove, test, and replace one bulb at a time. This will yell if one of the bulbs has a problem that may be effecting other down stream.
I have had one section of an LED ribbon strip start to flicker but it did not effect the rest of the strip
2004 Excursion 4x4
Old 08-10-2016, 08:34 AM   #7
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
Flickering Lights
Do all the lights flicker or is isolated either in front or rear inside coach?
mcomeaux is offline   Reply With Quote
Exterior LED lights flickering! roger4147 Lights - Interior & Exterior 5 07-10-2015 04:12 PM
Flickering Headlights!! frankandsue Mechanics Corner - Engines, Transmission & More... 10 03-08-2014 05:30 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
Flickering Shore Power Light The Flintstones Batteries, Univolts, Converters & Inverters 5 03-28-2009 06:17 PM
