Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 09-01-2003, 08:12 PM   #1
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
lack t v reception....
help! ah got no reception captain!.....Miss Moneypit is stored in
Wis. and parts for the batwing are at camping world in bolinngbrook.......i am asuming i have power to the batwing cuz my led lights...is it safe to assume that i need a new replacement head? do these head have a history of breaking down?
should just pick uup a new head....kinda hard to long distance troubleshoot.....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-02-2003, 09:05 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Send a message via Skype™ to uwe
Norby,
I'd say take the batwing off the riser ( held on by 2 pins) and then disconnest the roof top wiring.
Use a ong piece of coax and connect it to the amplifier, bypassing the wiring inside the trailer.
Have someone hold it up, and go see if your tv works.
If it does, You got wiring trouble, if it does not, then you shoud check the amplifier by plugging in the coax from the antenna directly to the tv. reception will be very snowy, but if there is reception, then you kow the batwing is ok, and the problem is likely in the ampifier or the wiring inside the trailer. so, if the batwing is good, then put it back and try the wiring with the tv, but bypass the amplifier. Another thought : Is the TV ok?
Good luck!
Uwe
www.area63productions.com
uwe is offline   Reply With Quote
Why do I carry a spare starter? PeterH-350LE Mechanics Corner - Engines, Transmission & More... 32 12-02-2009 05:39 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
TV Reception Assistance Thingy overlander63 All Argosy Trailers 4 09-01-2003 04:15 PM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 08:03 PM
