On my 1984 A/S, the door opens outward to the left hand.
Is this the same for ALL A/S??
I've read numerous posts abt the problems with doors opening while-in-motion,etc. This has caused problems to door frame plum, dents in the exterior skin and, even cracked windows.
I'm curious as to why the door opening hasn't ever been changed to a right-hand opening?? Seems that this would be a simple fix and, from a view point of safety, the 'best' method.
On my short A/S, the rear-opening door stays clear of the awning arm. I had interference there on a former SOB trailer.
OTOH, the open door on mine covers half of the refrigerator louvers which results in poor refrigerator performance when it is cool enough to want just the screen door but still pretty warm outside. Doesn't seem to matter any in cooler weather. See photos.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
All are good points, and I agree about the window. In my case, where I have a window on both side of the door..either window could be damaged in a sudden gust of wind..
It hasn't happened yet but, I worry some abt it opening all by itself while in motion.
John, your picture begs another question. 'What about the exhaust from your heating system?' It almost looks like it blockage there as well?
I don't want to get off track here, but you seem to have more to gain by having the door open in the opposite direction.
This picture of my unit shows both windows next to the door.
ciao
Mine has a deadbolt installed. I use only the deadbolt to lock the door. Who ever did it, did a professional job. Looks like it came from the factory that way. No way is the door coming open with it latched.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
Mine too has the furnace exhaust to the left of the door. My thinking is, you probably wouldn't have your door opened completely while running the furnace. If you did, you would probably do some type of damage to your door.
John
My SOB had a window to the right of the door. If we forgot about the open window we smacked the door right into the corner of the window glass frame. Over time it put a small dent in the door.
One of our little dogs was so used to that right hand hinge that on our first outing with the A/S he managed to bounce right off the door. He was used to me opening the door and once barely enough space opened up, he would jump from the ground into the trailer, bypassing the steps. In the case of the Safari, he jumped from the left side and didn't notice that the clearance was now on the right, not the left and promptly replicated a bird hitting a window.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
John,
Glad to hear that~!
When I looked at your picture here..I thought, that the second set of louvres were for your hot water heater or furnace. What's the second louvre opening for?
ciao
BTW
The exhaust from the furnace is way at the rear of the A/S, so no problem with that.
Top and bottom of the refrigerator compartment. The Internationals don't have a roof vent. Instead, there is a thermostat-controlled fan behind the upper louvers.
John W. Irwin
My 26ft Argosy has the heater exhaust/intake right behind the open door. First time I use the furnace, I had the door open to watch the kids running around. I now have a nice "shamrock" on the middle of the door. Oh well, I'm going to strip the paint soon anyway. I have a feeling though, that the soot from the first time use in probably years contributed to this. I can't believe that the door wasn't marked from before my use, and that in almost 30 years somebody didn't have the door open with the furnace? ..........
Well, maybe I was the only "smart" one?
Marc (with door opening back)
Our door opens with the hinge on the right. We don't currently have an awning, but on other '64 GlobeTrotters I have seen that do, the awning arms preclude the door from opening all the way when the awning is open. The door only opens to about 90-degrees.
The other alternative I have seen is a pole & line type awning that attaches into the track over the door/window....I don't have any pictures, but this option doesn't interfere with the door.
We haven't decide yet which option we will go with after polishing.
Below are two pictures of '64 GlobeTrotters with awnings from the VAC Estes Park Rally this summer.
Shari
P.S. Sorry for the finger in the right hand photo...
