Old 05-25-2018, 11:53 AM   #1
Ashley Falls , Massachusetts
just bought a 1972 overlander
I need much information on how to get started getting this trailer in shape. First I need to find out where I can order a set of keys and books for this trailer? I have to replace cushions and mattress. What is the best from airstream or made by a local upolsterer? thanks for any advice that I can get
55fast3 is offline   Reply With Quote
Old 05-25-2018, 12:11 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Much of what you are looking for you can get from the Airstream store.
https://store.airstream.com/shop/
Congratulations and welcome to the wonderful world of Airstreams.
Richard
Old 05-25-2018, 12:17 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
First thing you should do, if you haven't already, is to go to the "Portal" tab above, then scroll down with your eyes on the right hand side of the screen, and look for the download link of the "trailer inspector's checklist." Perform a thorough inspection of your trailer, and you will know that you would be extremely lucky if all you have to do is change out some soft-goods.
Next, order a "shop" manual for your trailer. You can get them from Airstream (as above), and a variety of other places as well, I think I got mine off of ebay. You can probably get the keys from a dealer.
You aren't going to be able to get manufactured upholstered cushions from Airstream for your year of trailer. A local supplier is probably the way to go here.
good luck!
Old 05-25-2018, 06:54 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Colorado: Welcome to Air Forums and the vintage Airstream hobby. I too purchased an Overlander 27'. Mine is a 75. I knew full well what I was getting into when I went shopping for a vintage project. My goal is to make a comfortable and reliable Airstream the whole family can use.
You need to assess your trailer's needs as Belegedehl suggests. If yours is a New England trailer, expect a bigger project due to the moisture of the environment. Mine was a Louisiana trailer with similar moisture rot. I too will replace the soft goods in my trailer except the curtains as they had already been done, but it is way down on the project list.
Check out the Knowledge Base, Airstream Trailer forums toward the bottom of the forums page. Find Overlanders, and then 72 and start reading. You will learn a lot about your trailer there. Note that the "seventies" trailers have a lot of similarities so your 72 isn't a bunch different than my 75. If you like, you can read my project thread and learn some about what I've been fixing. I have quite a ways to go yet. Here are photos of my trailer as I brought it home.
Hope this helps...
David
Name:	1709 Colorado Springs Awnings (Small).JPG
ID:	312014   Click image for larger version
Name:	1709 As found gaucho 2.jpg
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 05-25-2018, 07:48 PM   #5
1970 27' Overlander
Poteau , Oklahoma
Nice to get an Overlander or for that matter any Airstream. I am also a Vintage Overlander owner and like most its in various stages of progress bringing the ole gal back to ship shape. Here is todays work. project, and one many people forget about. I had a shutdown on my steps and got them in top notch working order again. I even got some new skid pads complete with racing stipes. Next year, by golly I won;t be landing 5 feet out in the camground the next time Oklahoma has one of its notorious Ice storms. Hope you enjoy your new/ole Airstream, I think you will.
cowdiddly is offline   Reply With Quote
Old 05-26-2018, 09:37 AM   #6
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Welcome. On my 74, and I suspect your 72, the water door and compartment locks are standard keys. Seems strange, but every one used the same key. I got my replacements from out of doors mart odmrv.com.
Good luck with your projects. We'd love to see pictures.
TheGreatleys is offline   Reply With Quote
Old 05-26-2018, 08:01 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi cowdiddly: Nice job on the fold down step. I see it is of the same design as my son's 69 Globetrotter. My 75 Overlander has the aluminum fold over "two step" design that Airstream used for many years. My 86 has the same aluminum steps.
I wonder what year Airstream started using these aluminum two step steps.
David
WBCCI #8607
VAC Region 11
Old 05-27-2018, 05:58 AM   #8
1970 27' Overlander
Poteau , Oklahoma
Hi how you doing DBJ. I must say Your camper is in nice shape for sure, Score!
.Yes, I had a 78 that did the Texas Two Step thingy. Well just from these posts we can deduce that the 2 step model was started in either 71,72, 73 or 74.
My bet would be 1971. They made a lot of changes that year.
At any rate I think that the single step is just to cool for school. Just give the little tin hand hold a slight tug and it just jumps out ready to go. Its so simple and efficient it hurts.
The older I get I have come to understand one thing. The simpiler you can make something and less moving parts the better it is. LESS IS MORE.
Old 05-27-2018, 08:54 PM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Cowdiddly
I have a 66 Tradewind with the single step and I love it. It is so simple and works so well.
My son and daughter in law just bought a 78 Caravanner and it has the Texas 2 step. BTW they live in Fort Worth.
Dan
Old 05-27-2018, 09:18 PM   #10
1970 27' Overlander
Poteau , Oklahoma
Originally Posted by TouringDan View Post
Cowdiddly
Dan
a 66 Tradewind. I would love it toooooo! I actually think the 66-67 was the high watermark interior wise in quality in the vintage Airstreams. Yours has metal cabinet latches I bet. I would die for a set of those.
I only went a little later to get the vista view windows and I got a good deal on it. but I wish the interior was a like a 66/67
Just Shoot Me, I just bought another Airsteam 54 Flying Cloud KrisE MN 1950-1955 Flying Cloud 25 07-03-2017 06:44 AM
Pristine 64 overlander just bought- should I replace anything? robwok Cabinets, Counter Tops & Furnishings 8 05-06-2011 08:00 PM
just bought 1972 Excella 500 31', what to do next! 72-500 1971-1972 Excella 500 31 02-22-2011 10:37 PM
Just bought '69 Overlander, work in progress jayg Member Introductions 2 10-24-2010 07:23 PM
Just bought 68 Overlander Air Hamel Member Introductions 13 05-26-2008 05:06 PM
