Old 08-10-2004, 07:49 AM   #15
ctdair's Avatar
The vinyl floor in our 2004 was completely relaced along with the bedroom carpeting , this required allmost a complete interior removal and replacement
any thing that sat on the floor came out as our trailer is wall to wall vinyl except for the bedroom and the tile is laid under all the cabinets. anyhow it would take longer but I would go for the full replacement the interior will look the same when done. You may know but no one else will be able to tell there was ever a repair made or the interior was removed. They will have direct access to the rear of the anel to seal better. if it was mine id go for the orginal bucked rivets not olympics for that large of a job.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 08-10-2004, 10:06 AM   #16
Ed & Debbie
The secret to success of metal replacement is not the kind of rivet, but in the quality of the labor.
Olympic rivets have been around since the early 70's.
Done properly, metal replacement anywhere on an Airstream trailer or motorhome using "olympic" rivets is equal to the "buck" rivets.
The olympic rivet was designed to save labor costs, without sacrificing the quality of repair.
On the other hand, a buck rivet job, can be just as bad as a poor olympic job, again depending on "how it's done."
After market metal replacement, requires an injection of "Vulkem or Sikaflex sealer" within the seams to insure a "positive seal."
The theory of "keeping it original" holds little water, when it comes to resale value.
Again, the key to it is "the quality of the labor."
The only issue with olympic rivets is which one to use. There are two types, one with a washer and one without. The washer is neoprene. Neoprene being what it is, expose it to hot weather, over time, and the washer "will" fail, which in turn, probably will fall out, and possibly causing a water leak. Additionally, a washered olympic rivet allows you to put your finger nail under every rivet head, making the repair job less desireable.
The washer type olympics in our neck of the woods desert, have been known to fail in less than two years. Also the washer type olympic rivet, in my opinion, is a sorry excuse for a quality repair job, in that your depending on it to "not leak." Good luck if you use it.
Small fire at Service Center at Jackson Center hohne Our Community 32 06-07-2004 11:00 PM
Estimates from Jackson Center? Kistler Commercial Listings 18 12-15-2003 02:14 PM
A question about the “Winter Program” at Jackson Center, Ohio nds Commercial Listings 1 11-30-2003 01:40 PM
Ever toured the Jackson Center plant? KY Girl Our Community 21 11-17-2002 11:04 PM
