Old 10-13-2014, 02:42 PM   #1
gomotomoto's Avatar
Longport , New Jersey
Is this a heater?
Name:	ImageUploadedByAirstream Forums1413232842.606539.jpg
Anyone know what this is? Looks like a heater! If so - I need it!
I saw this on one of the airstreams in the classified section
Looks like it's vented to the outside, which I like opposed to the catalytic heater.
Our airstream was redone in Florida in the original furnace was removed along with ductwork.
If anyone is familiar with this it would be a huge help if you someone could help me identify it
gomotomoto is offline   Reply With Quote
Old 10-13-2014, 02:53 PM   #2
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
It is a fireplace. Pursue the classified and ask the owner where they got it. Google marine lpg fireplace and see what comes up.
Gearheart is offline   Reply With Quote
Old 10-13-2014, 02:59 PM   #3
gomotomoto's Avatar
Looks awesome. Think this is it:
What do you guys think?
Old 10-13-2014, 03:55 PM   #4
pbearsailor's Avatar
Port Hadlock , Washington
It's a Dickinson Newport propane heater. Mine has been used in my trailer for four years now.
It's great!
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-13-2014, 04:44 PM   #5
terryV's Avatar
2002 31' Classic
Monroe , Iowa
WOW, that is about as cute as cute can be! I want one, and I don't have anything to put it in.
terryV is offline   Reply With Quote
Old 10-13-2014, 05:21 PM   #6
gomotomoto's Avatar
It's great!
-steve
Heats it up no problem?
I have no furnace, so this is an awesome solution.
Did you mount it yourself?
Old 10-13-2014, 05:21 PM   #7
gomotomoto's Avatar
No airstream?
Old 10-14-2014, 08:46 AM   #8
Yeah, I've used it down to 20 degrees or so. Always going to be warmer near the heater than at the end of the trailer, but it's fine.
Install is pretty easy. Gas, 12 volt power, and a hole in the trailer.
The pipe is double walled so it draws air in through the same pipe that it exhausts, so it is totally sealed from the air in the trailer. 12 volt usage is very low. You'll probably need at least one piece of extension pipe for it as well, depending on how high you mount it.
There is probably some more on the install in my thread linked below.
-steve
Old 10-14-2014, 08:47 AM   #9
gomotomoto's Avatar
-steve
Thanks Steve! I'm pretty pumped to put one in.
Water heater/ heater matrix repair montreal Classic Motorhomes 2 06-08-2012 06:00 AM
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
