We just got back from a 4 night trip with the trailer. It was our third time out since much of the restoration.
I have some questions about some of the operations.
It was 100 degrees outside and the new Dometic 2510 fridge had to be set to max temp setting on gas to keep it cool. At first I thought the a/c portion did not work but it may have been that I had it set too low on the thermostat. I just kept it on gas/max since it started working.
Is it normal to have to adjust the fridge thermostat depending on the outside temp?
As a side note, the fridge door kept falling off all week. There is a nut on the bottom hinge that moves everytime the door is opened until it falls off!
The new atwood gas, pilot model blew out three times and needed relighting. Is this normal? It was breezy in the afternoons.
The new Penguin A/C kept the trailer at 80 degrees on the 100+ outside temp days running full time on max. I thought that was pretty good. Should it be better?
All in all we had a good time despite the little problems. I would like to expect the appliances to work a lot better given the amount I paid for them!
