Old 07-07-2003, 11:50 PM   #1
Trout Fishin's Avatar
Unhappy Is it a good deal?
I have a friend that is wanting to sell his 78 ( I think) Ambassador 28. It has been used as a fishing cabin and has not been moved for the last 10 years. He says everything works but needs updating. He is asking 2K for it. Is this a good deal? Will my Ford Explorer V8 with towing package pull it? What should I look for before I take the plunge? I have always wanted an Airstream and this seems like a good deal. Please help.
Trout Fishin is offline   Reply With Quote
Old 07-08-2003, 03:45 AM   #2
sjptak's Avatar
If I was closer to Texas, I'd probably scarf that up in a heartbeat. I haven't been able to find anything in that price and the 25' I did find with a good size dent, no fridge, rotten floor be door, they wanted $5K. But. I'm only a wannabe. Listen to the others for the voice of experience.
Good Luck.
Stan and the Lou
Together Forever
BTW, that's MaryLou
sjptak is offline   Reply With Quote
Old 07-08-2003, 07:06 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Is it a good deal?
Greetings Trout Fishin!
Welcome to the Forums!
The '78 Ambassador that you are looking at has an empty weight of 4,630 pounds with a hitch weight of 550 pounds (twin bed floorplan) or 575 pounds (double bed floorplan). You can find this information at:
Airstream Weights and Measures
These weight are both empty and each will increase significantly once the trailer is prepped for a vacation trip. What empty means is that none of the installed options are included in the figures nor are any fluids such as water or propane included in these figures - - the holding tank(s) are also empty.
To give you an idea of what loaded weight might look like, my '64 Overlander has an empty weight (with all installed options) of 4,440 pounds with a hitch weight of 475 pounds - - when it is fully loaded ready for a vacation, the coach approaches 6,000 pounds with a hitch weight approaching 750 pounds.
I suspect that your Explorer would be maxed out on its trailer towing capacity if not in excess of its rated capacity. Another issue to consider is the diparity between the wheelbase/length of the tow vehcile compared to the length of the trailer - - the greater this disparity, the higher the probability of an uncomfortable towing experience; and this can be compounded in circumstances where the trailer is significantly higher than the tow vehicle. If I were looking at a trailer of this size, my preference would be to have a tow vehicle with a trailer tow rating of at least 7,200 pounds to allow for a margin of safety (IMHO).
The price at which the trailer is being offered is very attractive. If it is truly fully functional so far as the interior components are concerned, it MAY be a very good buy. The length of time that the coach has been setting would indicate that the following may be issues that will need to be addressed:
1.) The tires will be a near certain replacement item.
2.) The bearings and brakes will need to be serviced before any serious towing is considered.
3.) If the trailer has the optional(?) vacuum over hydraulic disc brake system, they will likely need service to be functional; and there are two chanins of thought on whether it is better to overhaul these units or replace with the more readily available electric drum brakes.
4.) The axles may have taken a "set" during this extended period of inactivity which MAY result in a fast road to replacement requirements.
5.) The propane tanks will likely need to have their valves replaced with the currently required OPD valves - - not an excessively expensive modificatgion, but may be time consuming in trying to locate the valves for aluminum tanks if the coach is so equipped.
Even with those four issues involved, if the interior appliances are functional, the exterior skin is in good condition, the floor is sound, and there is no evidence of unrepaired rear end separation or droop ; the price may very well be within reason.
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Great Deal on a Bambi Order DreamStream Commercial Listings 10 01-31-2004 06:46 PM
Good deal on Mobil 1 Oil... Silvertwinkie Our Community 28 05-16-2003 04:18 PM
