Old 08-12-2013, 03:54 PM   #1
SummitAir's Avatar
1970 27' Overlander
Summit , Mississippi
Inverter or Not
I have a 27' 1970 Overlander Land Yacht. When I disconnect from shore power I have no battery power for lights, fridge, etc. No blown fuses and battery is new and tests good and fully charged. I still have the original inverter and it buzzes like normal when powered up. Any ideas?
SummitAir is offline   Reply With Quote
Old 08-12-2013, 04:04 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You actually mean converter, I believe. Do you have a battery disconnect switch somewhere that is disengaged?
TB & Greg and Abbey Schnauzer
#3954
Old 08-12-2013, 04:11 PM   #3
SummitAir's Avatar
1970 27' Overlander
Yea sorry. I did mean converter. I do have a battery disconnect switch but it is engaged. When I switch it on the converter buzzes. When I switch it off it stops buzzing. This one has me baffled.
Old 08-12-2013, 04:32 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Measure the voltage between the negative battery terminal and body ground. It should be zero. If you see 12 volts you have an open ground.
Some trailers of that age had a large fuse in the ground lead. Regardless, if there is voltage on that reading follow the negative lead to the point where it grounds to the body. If by chance there is a large cartridge fuse in a ceramic holder check the rivets that hold it together as well as the fuse
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-12-2013, 04:39 PM   #5
SummitAir's Avatar
1970 27' Overlander
Ok. Will try that. Thanks!!
Old 08-12-2013, 04:46 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you have 12v when your verter is coning then it must be working. Ergo, the problem is somewhere between the verter and the battery.
Old 08-12-2013, 05:07 PM   #7
SummitAir's Avatar
1970 27' Overlander
Thanks Lumanic.
Old 08-12-2013, 05:07 PM   #8
SummitAir's Avatar
1970 27' Overlander
*Lumatic. Lol.
