Old 04-15-2003, 09:00 PM   #1
JWest's Avatar
Smile I'm upgrading my tow vehichle
Hi everyone, thanks for your help in advance.... I have a 30 foot, 2002 Classic w/ slide out that I bought last Nov. ( Got to use it once before winterizing). I have been pulling it with a 3/4 ton Ford 4x4. I am thinking about buying a new truck and wondered if anyone could suggest my best option. 3/4 ton vs 1 ton ? Gas vs Diesel ? 4x4 vs 2 wheel drive? and Automatic vs standard?
I am leaning towards a 1- ton diesel, 2 wheel drive with an automatic transmission. How about reports on Ford vs Dodge vs Chevy? Any thoughts are appreciated, I don't want to spend a lot of $$ to find that I bought the wrong tow vehichle.
JWest is offline   Reply With Quote
Old 04-15-2003, 10:08 PM   #2
You will find too many people with preferences for each and every one of those choices to demonstrate that ANY of them are "wrong". Any of them may be wrong for YOU, however. So much depends on your preferences.
Just a couple of thoughts, though. If you park your rig on an upaved surface (as I do), or often camp in state parks or other settings where surfaces can be wet and slippery - wet leaves, for example - there is no substitute for a 4X4. If not, then four wheel drive is just extra expense, extra weight, extra maintenance, and extra drag on the drivetrain.
It is likely you can get either a 3/4 or one ton with the right gearing/engine package to meet your needs. In some cases the difference will only be the tires! And one make may have a 3/4 ton that would work well while in another you will have to go with a one ton. Quiz each dealer closely.
You either love a diesel or you don't (I do). You may as well drive some and see what you think.
I love the control of a manual when towing. It hurts resale, though, and frequently has to be special ordered (depends on the buying habits of those in your area). And the new five and six speed automatics with towing modes are getting rave reviews from owners.
Dodge, Chevy, or Ford? Yes, I think one of those would be fine.
Mark
Old 04-15-2003, 10:28 PM   #3
About 4x4 vs. 4x2...
March and April have been really rainy months here in the South and my truck + A/S got stuck near the driveway. The soil is saturated with water. The big rear-wheel drive truck doesn't have any tension at all. I couldn't move the unit and I barely was able to get the truck out after a week of trying. I am not thinking about moving the A/S until maybe May when the heat gets stronger and we get maybe 10 days in a row without water. What a contrast with the terrible drought last year.
Earlier, I was moving the truck and forgot where I had my garden last year - and drove right over it. Over that soft, oversaturated soil. It literally sank in the soil under its weight, up to the axle and deeper. All that big-block power was useless. Took me a day to get out.
Still, I like 4x2 just fine, it just means I cannot park anywhere. Empty, it does get stuck very easily off road after a recent rain. So, I don't take it off road and certainly not after spring rains.
It depends on your requirements, how much you will tow (2 times per year or every other week), where you will tow (Kansas or Appalachia?) and what you will carry (empty or loaded) Take your truck and unit to the mountains and that will impact your attitude about towing vehicles.
A 1 ton like mine will definitely do the job. But it is also the truck that handles like a 1 ton and gets the mileage like a 1 ton. It is a truck and I don't see myself driving it more than 4-5K miles per year. Which explains the low miles on it when I got it. I don't think any of these big trucks handle very well or get great mileage. They are built to tow.
Whatever you get, get an over drive, that's my only frustration with my truck. Although I hear my 3-speed tranny is bullet proof.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 04-16-2003, 08:29 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Bigger is better and SAFER.
For the price difference between a 3/4 ton and a 1 ton, I would get the 1 ton. Gas or diesel? Gas is more economical up front. I got 10 mpg on my first outing this year, over 350 miles round trip with my big block. The new GM and Cummins diesels are super quiet. I wish they were not so expensive at $5000+, I would like to have one.
Another consideration is an extended cab or crew cab pickup. The extra wheelbase length makes for a more stable rig.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-16-2003, 08:35 AM   #5
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I'm a Chevy guy by nature but I really like the Ford Super Duty trucks with the Power Stroke.
It would be a tough call for me between the Chevy with the Duramax and the Fords. They are both good trucks and both pretty evenly matched as far as pulling power, comfort, reliability, millage. I really don't think you can go wrong with either.
Like was mentioned, you might want to look at the 3/4's verses the 1 tons. The weight is behind the truck and not in it. The drivetrains are identical between the 3/4 and 1 tons on both sides. It's spring rates and frame hight is the only difference. You would be giving up ride and not really gaining anything that you need in return. It's not really needed unless you plan to load the bed full of dirt regularly.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 04-16-2003, 11:42 AM   #6
Getting ready to order a new Safari so I had to get a new truck to pull it up some tall mountains here in the west. Got a new Chevy Silverado 2500HD Duramax Diesel w/ Allison Tranny. Best news is 0% interest 60 months!!! I don't think this promotion will last long so now is the time.
SASS #41766
Melvin P. Thorpe is offline   Reply With Quote
Old 04-16-2003, 11:52 AM   #7
What ever you get, make sure you do not have 16.5 tires if you do a lot of travelling.
We had them, along with nightmares stories: you cannot find them when you need them. (on example: blow-out in CT, couldn't find one to buy right away in CT, MA & ME. Used spare. Order one in NY. Flat on the Mass Pike: towing van and trailer out of there,.....)
femuse is offline   Reply With Quote
Old 04-16-2003, 12:55 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Interesting, I'm looking to up my towing capacity and am considering a Chevy, GMC, or Ford van. The 2500 series Chevy or GMC with the Vortec 6000 engine and 4.10 rear end will handle between 9,600-9,900 lbs dependent upon the data source I'm looking at. It shows 16 inch wheels so I'm curious about the 16.5 tires statement.
The Ford E350 has the V10 engine which will handle 10,000 lbs. From what I have found so far, nothing in the V8's will get me capacity in the 9,000+ range.
My current van is a '99 Chevy Express with the 5.7 liter engine. Since this vehicle is occasionally used by my wife as her personal transportation, handling is an important factor to her. She has not liked the Chevy and considers it inferior to our previous Chevy van which was an '88 Beauville (that had a little lower profile) and seemed a little more stable.
My son has driven a company owned Ford E150 van which he says is more "car like" in handling than my Chevy.....hence why we are also going to consider Ford.
I'm not a pickup person and quite honestly the $12,000 premium that a Surburban fetches puts me out of the picture for that type of vehicle.
Are any of you van folks who can relate to the 2003 models from GM or Ford?
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-16-2003, 01:20 PM   #9
We do not have experience with 2003 vehicles. What I can tell you about a 1990 Chevy cargo G-30, 454, extended wheel base (146"):
When Chevy added their extra cargo space they put it *between* the axles, created better weight distribution, lengthening the wheelbase in the process, and producing a very short overhang beyond the rear axle.
With a longer overhang (an extended Dodge van for example) when you add your trailer hitch to the back of that rig, you are providing a long lever by which the trailer gains influence over the tow vehicle. The short overhang of the Chevy reduces that leverage.
We used that same van for roughly 9 years, with a 25' then a 29' (over 6 years). With dual cams, this made for a very stable rig.
About the tires: we towed with that van for about 90,000 miles. We used load E. It was always a problem to get them when in a hurry. I know some manufacterers stopped several years ago making them. We were left with 2 acceptable choices : Good Year Eagle (had silent recall on load E _ we had several with problems) and Bridgestone.
The answer we got at a lot of tire places was: "Not a very popular size. Change to 16"
This was load range E. Load D may be easier to get.
One last thing about a 454 in a Chevy van: it's nearly impossible to do any work on the engine. The usual comment is "Man !!! it's crowded in there". But it tows like a dream.
Old 04-16-2003, 01:40 PM   #10
jcanavera's Avatar
Fenton , Missouri
Images: 143
What I am looking at is not an extended version so physically it will be very similar to my current 1500. This is the first year that GM has put the newer style engines into the vans so I'm not sure what the Vortec 6000 equates to in the older GM perspective.
I do know that my Vortec 5700 V8 in the '99 is squeezed in so I know what you mean about working on things. There used to be a Vortec 8100 engine which I assume is the 454, but it and the 6.5 liter diesel are no longer options on the 2500 vans. I have a neighbor who has had two Chevy pickups with the Vortec 5300's and he can't stop saying good things about them.
I'm off Friday so I'll be looking and test driving. Unfortunately no one within 250 miles of St. Louis has what I want so we probably will have to have one built if we decide to pursue the GM side of things. Unfortunately the $3,000 rebate expires month end and they can't get one turned out that fast although 15 days is all they need currently.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-16-2003, 01:49 PM   #11
The 2003 2500 HD Duramax has a trailer towing capacity of 12,000# and it comes with 16" wheels. 5th wheel towing capacity is much higher, something like 16,000-19,000## if I remember correctly.
SASS #41766
Old 04-16-2003, 02:13 PM   #12
jcanavera's Avatar
Fenton , Missouri
Images: 143
Unfortunately not an option on the van side from GM.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-16-2003, 02:23 PM   #13
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
There is a difference in 1 ton drivetrains...
Brakes and rear end. 1 ton, hydraulic assist, 3/4 ton, vacuum assist. 1 ton has larger rear drum brakes than a 3/4. The rear axle and rear end is also larger. I am refering to GM trucks. I don't know about the Dodge or Furds.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-26-2003, 09:41 AM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
Unhappy Disappointed
I thought I would play it safe and make sure that if I do the upgrade to the GMC2500 van from my current 1500, that it will fit in the garage. The dealer didn't have a passenger unit so I took a cargo one home. I stood on a ladder while my wife slowly drove it into the garage.
All was fine until we got to the rear axle. The clearance quickly went to 0 and I realized it wasn't going to fit. Major disappointment since all of the GM specs and calls to GM assured me that the van would clear my garage door opening. Specs on the cargo van are the same as the passenger, but without seats carpet and glass, that rear end just sits too high off that rear axle.
I'm not sure what I'm going to do now. Unfortunately the Surburbans are out of my affordability range, so if I want more towing capacity I may have to go to pickup land.
Jack
Jack Canavera
STL Mo.
AIR #56
What to tow a minuet with? Stefrobrts Tow Vehicles 17 01-03-2016 01:47 PM
More on tow ratings ipso_facto Tow Vehicles 19 11-16-2004 04:11 PM
Which to tow with? Windstar or F150 dmbcdn Tow Vehicles 20 11-11-2003 03:03 PM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
Newbie Tow Advice Needed Mr. Bliss Our Community 12 02-26-2003 05:16 PM
