05-05-2003, 06:37 PM
1968 17' Caravel
Battle Ground
I think my tow vehicle's a lemon!
Last week I took my new '95 E150 over to a friends house to pick up the hitch he was selling me, and the next day I was supposed to bring tow over the trailer to have the friction sway control ball attached to the tounge, but I had to postpone because the ASB light came on on the van during the drive home. So away it went to the ford dealer, and they replaced the ABS computer for $1100 - ugh. But that's ok, you always expect some repairs when you get a used vehicle.
So everything seems ok, and my husband uses it to take our packages to the post office at the end of the day today, and comes back and parks it on the gravel next to the driveway. Then he goes out to leave for a meeting about a half hour later, and I walked out to the car with him, and when he backed up I noticed a two foot dark puddle on the gravel where he had been parked. So I signalled him to stop while I checked it out - GAS! So he pulled the van back up onto the paved part of the driveway and took my Bronco instead.
Well, I can see where there's marks on the gas tank where something stained it, must be the gas, but how could they have missed this at Ford just a few days ago? And now it's not dripping anything on the driveway, even though it left a substantial puddle on the gravel. I even started it and let it run (once the gas fumes had dissipated). Nothing. How aggrivating. We were going to take the trailer over to our friend's tomorrow, but now it looks like we'll be putting that off again while we find the gas leak. Two rather serious problems in a week is bad news only a week after bringing it home! And to think I bought it so we'd all have a safe reliable tow vehicle for the new trailer. If this keeps up I won't trust it to tow the AS!
Stephanie
05-05-2003, 06:42 PM
Aluminut
2004 25' Safari
Sorry to hear that Steph. Hopefully they are isolated happenings and you'll get back on track soon.
Eric
05-05-2003, 07:13 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
Gas leak?
Steph, I too have had a "mysterous" gas leak ... in my Astro van! I've noticed the smell has a pattern. I've just filled up, and it's a hot day. It only happened occasionally during the summer before, then never again this winter - spring. I was able to figure out that somehow the gas either came out the filler hose and stuck in the drain hose by the fillerneck - only to come out after I moved OR it vented out on a hot day (both times only when it was sunny). I work nights, so I'm trying to figure out if this happened on one of our WA sunny days recently, or am I barking up the wrong tree. One thing on mine though, it did not leave a puddle, just enough for the smell to drive me crazy.
You may want to look to see if somehow when the dealer was diagnosing the brakes if they disrupted the fuel lines at all? Did the prevous seller have any problems reported?
I know your feelings about an unreliable truck, I don't trust the Astro as is (possibly leaking head gasket now - it's been a bucket of bolts!). I'll be looking for a new something soon!
Marc
05-05-2003, 07:38 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Stephanie!
There is nothing more discouraging than difficulties with a recently acquired vehicle. What you are experiencing may not be a serious problem, but is one that needs attention. Some of the culprits that I have encountered included:
1. Defective filler neck connector hose, or loose clamps on either end of the hose. On at least two of my vehicles this has caused a problem when the tank was completely filled and then sat out in the sun on a warm day - - fuel would begin seeping or leaking out the areas where the hose was clamped onto the fixed part of the filler or the tank itself. In either case clamps or a new hose the fix was neither costly or difficult.
2. Pin holes, or rust out on top of the tank. This was a big problem with my mid-1970s GM vehicles in the humid areas of Southern Illinois. At something between 5 and 8 year intervals, all of a sudden a puddle would appear under the car with no visible damage to the visible portions of the tank - - when the tank was dropped, the top side would be riddled with pin holes or would be nearly entirely rusted. This may not be the case with your 1990s Ford as it may have been equipped with something other than a steel gas tank.
3. Vapor or fuel return lines may be leaking, loose, or disconnected. (It is also remotely possible that a malfunctioning vapor cannister could cause some fuel to percolate through the system. I only had this problem with one vehicle, and it was a '71 Buick.) With fuel injection, the fuel return line to the tank has caused problems on each of my fuel injected vehicles after approximately 50,000 miles - - replacing the non-metalic fuel return lines cured the problem in each case.
4. A leaking fuel filter could also cause a puddle like you are seeing. This would be a long shot, but according to the mechanic that services my tow vehicle it is one of the more overlooked regular service/maintenance issues (when I had my father's recently acquired '94 Chevrolet Blazer serviced my mechanic didn't think that the filter had ever been changed and it was leaking).
5. My '75 Cadillac Eldorado had to have one of the more unusual such leaks. It only happened when I filled the tank very full on a warm day and then didn't drive it at least ten miles. A puddle would form almost dead center under the tank - - as it turned out a mechanic had left the gasket around the fuel sending unit out and the fuel was being forced out around the sending unit due to the lack of the gasket.
Good luck in locating your fuelish gremlin.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
05-05-2003, 07:39 PM
1968 17' Caravel
Battle Ground
Funny you say that, because we did just fill it up on Saturday, for the first time since we bought it. I was thinking there might be a loose connection at the junction where the filler tube goes into the tank, causing the gas to leak down or spill out. Today was a warm day, compared to recent weather. I don't know if that makes any difference.
I'm just sure this is exactly the tow vehicle for us, if we can just work the bugs out. Just wasn't expecting so many bugs so soon I guess!
Stephanie
05-05-2003, 08:02 PM
"Funny you say that, because we did just fill it up on Saturday, for the first time since we bought it... Today was a warm day..."
Might be a problem with the tank venting system.
Mark
05-05-2003, 10:26 PM
1959 22' Caravanner
Atlanta
, Georgia
That's odd on the fuel. That van should be new enough that if it had a leak in the fuel system it should trip a check engine light (Part of OBDII emissions). Did you atempt to top it off and get that least drop in? Maybe some ran down the filler neck and puddled on the top of the tank?
Yep used vehicles and even new vehicles will toss you a few curves.
The Suburban I picked up was VERY well maintained. Still found a few problems I am taking care of. The PO didn't put many miles on it in the last couple years and some "age" problems are creaping up. I have spent over $500 on it since I bought it. No big deal stuff but still things I wanted to take care of. Shocks appear original and time to be replaced, replaced a couple hoses that appeared original and had age cracking, Thermostatic fan clutch has seen better day's and causing it to run a little warm at idle with the A/C on. Bad exhaust gasket that I need to replace this weekend. O2 sensor was due to be changed. Did a full blown Tune up including plugs, wires, cap, button and timming. Chasing a surge at cruising speed that I think I have about got rid of. Most of it was old plug wires. I think the last will be a dirty fuel filter.
Found a couple items that were the fault of others that had serviced the vehicle. Heck the funniest is I found a problem that I found a complaint on from the PO's PO. This truck had a problem with intermitant High on the blower and it was back at the dealer for this complaint when it was about a year old according to the paperwork that came with the truck. Whoever wired the truck for the trailer brakes left a nut loose on a terminal block 13 years ago! It has been in multiple times for this complaint including the week before I purchaced it! I found it after looking at a wiring diagram for ten minutes and testing a few points with a test light LOL.
Not at all unhappy with it and like I said the PO took great care of the vehicle. Just had not drove it much and didn't notice a few items that had crept up. He's the type that had he known there was a problem it would have been taken care of. It was by far the best one in Atlanta when I was ready to buy. I'm sure I would have spent far more on any of the other trucks to get them up to snuff. I still feel ahead with this one by a long shot.
Thankfully I'm pretty handy and can take care of these things myself. The PO was also super nice and gave me a factory service manual and it's helping a ton. I would have been well over $1k in minor repairs if I had to take it to somebody to do this work.
Once you work through a few bugs you will be happy with your new tow rig. It's just showing it's age and better you find the problems now then when your 1,000 miles from home in the middle of nowhere. Give it some TLC.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
05-05-2003, 10:41 PM
Austin
Ouch,
1100 bucks for an ABS controller! At least you know the PO wasn't trying to cover anything up or else they would have simply pulled the ABS indicator bulb out, the easiest fix by far but not necessarily the safest. As far as the fuel leak maybe someone replaced the fuel pump and failed to reconnect all the hoses correctly. I had a fuel pump replaced on a service truck I had years back and they failed to hook up the fill spout. My first fill up was pretty exciting!
Chas
05-05-2003, 11:32 PM
1968 17' Caravel
Battle Ground
The first time I filled up my Bronco I was beginning to think the filler tube wasn't hooked up - I actually looked under the truck to see if the gas was pouring back out somewhere :-) Just a really big tank.
I'll give the van a good going over tomorrow. My husband's got to be at a meeting all day, and I'll have nothing else to do but tinker with my trailer and tow vehicle. I really think the advice to check the vent hose, filler tube, etc sounds good. Seems like fuel pump or fuel filter problems would leak pretty constantly. This must be a full tank issue, or a warmed up issue, since it did it right after a trip into town and back. I'll try not to blow myself up troubleshooting it (and I'll keep it far away from the AS while I do it)!
Stephanie
05-06-2003, 07:57 AM
Moderator Emeritus
1972 31' Sovereign
High Springs
Fuel Filters
I have had problems with fuel filters rusting out on both Ford and GM vehicles. They put the darn things in the frame, near the rear of the vehicle. All the corrosive road crap catches in there and does a number on the filter. You may want to have it replaced as a preventitive measure.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
05-06-2003, 09:11 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
another thing you can check: I had this happen to me on my 87 dodge dakota, and it took quite a while before I (and my mechanic) figured it out. Some days, I would only smell the gas...but no puddle. on really warm days, and when the tank was nearly full, there might be a puddle. The tank was plastic; no rust there. What it turned out to be was the sending unit, which goes into the top of the tank. (tank has to be pulled to really inspect it well). it had a couple of metal tubes on it, to which attached the rubber fuel/vapor return lines that head off to the engine. the metal tubes were rusted. at medium tank levels, on moderately warm days, there would only be enough fuel leakage to make a small puddle on top of the gas tank. enough to smell, but not enough to overflow and spill onto the pavement. It would only spill over on hot days when the tank was full.
it was surprising to learn that you can have fuel leak from the top of the tank.
05-06-2003, 11:18 AM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Tank
Hi Stef,
Run the van until the tank is almost empty. It might have to be removed to properly diagnose the problem. This is very easy on your van, just a few straps and the filler neck fitting must be loosened, and then the tank can be lowered enough for inspection. The job is easier with an almost empty tank.
One thing you can do in the meantime, is take a flashlight and a mirror and follow the dark stained area up, you might just be able to see where the stain originates from. Wear clear safety goggles. Dirt will fall off the bottom of the van and find your eyeballs, trust me. And please be safe, and have someone with you while you do this, especially if the vehicle needs to be jacked up for you to fit under it. I have a 1 ton van, and it is high enough off the ground to where I can slide under it completely, without jacking it up.
Did the van have full ABS or just rear wheel ABS?
I owned a Ford cargo van for many years, and I want to assure you that it is a very good vehicle. Actually like it much better than the current Dodge. It was by far a much better build vehicle. I think that if you take good care of it and get over the first few month of ironing ut some minor bugs, then it will be a great van for you guys to own.
I do not think your van is a lemon because of what happened to you. No worries..
05-06-2003, 11:40 AM
1999 34' Limited
2002 19' Bambi
Allen
Hang in there..
Steph,
Even a brand new tow vehicle can have problems. Ours decided to intermittently play the hard to start game. Fortunately the problem did not leave us stranded and the Ford dealer found the issue as soon as we returned from our first A/S outing. Turned out the fuel pump was not developing adequate pressure at times and therefore the fuel rail for the injectors was not upto pressure. We feel fortunate that this is the only issue we have encounter.
From what you have stated, I bet you have a situation where the tank was filled at a cooler temp and to the very top. The next day, the temps rose and the gas expanded. Gas tanks have a built in expansion chamber that is designed to allow for this expansion, but if you top off, that expansion area can also fill and then there is no room for expansion, so the gas finds another place to expand. The leak may have been any number of places that have already been mentioned, sender unit, hoses, vapor reclamation system, etc. I would try not filling the tank as full for a few times and see if the problem reoccurs. If all seems well, then try a topped off situation and see what happens. Even in a topped off situation, a leak is a leak, and I would want to know where it was occurring and make sure that a more serious leak could not develop in the future.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
05-06-2003, 03:28 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
Had the sme problem 3 times.
Once on a 1959 XK150 Jag and twice on a 1979 F250 P/U.
Only happens when full.
There is a short rubber hose between the filler where the gas cap is located and the tank itself. The hose in the Jag and P/U was rotten and in the second case of the Ford after a new hose was installed the hose clamp was not tight enough.
Beware its a real pain to change out the hose but it is not a big buck item.
Good luck
Garry
05-06-2003, 06:40 PM
1968 17' Caravel
Battle Ground
I looked it over this morning, but it was hard to see anything up there, and the whole driveway stank of gas, so I decided to run it down to the Ford dealer and let them take care of it. I know from restoring the mustangs, there is no job quite as nasty as one that gets you soaked with gas. So I left it to the pros. They called back and said the filler neck was broken, and they'll have it fixed and back to me by tonight or in the morning. I'll be another $300 poorer (the labor cost more than the part, probably just draining that tank to drop it and do the repair), but it's worth it to have it done right and not get my pretty little hands dirty. I spent the rest of the day getting the trailer ready to go. Much more pleasant.
Stephanie
05-08-2003, 12:48 AM
Stefrobrts,
Suggestions:
Get a "service manual", (Ebay is a good source)
use excellent resources such as
www.ford-trucks.com
Fuel systems can be really frustrating, they have gotten complex since carburator days.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
05-08-2003, 06:37 AM
Aluminut
2004 25' Safari
One nice thing about the Caprice is that the filler neck is easily accessed.
Now the spark plugs are a whole different story.......
Eric
05-08-2003, 09:05 AM
1968 17' Caravel
Battle Ground
Surprisingly, after taking two classic mustangs completely apart and putting them back together, the last thing I want to do when one of my every-day cars breaks down is work on it myself. Hopefully this one doesn't have anymore suprises in store for us. I will be getting a manual though. If nothing else it lets me do some troubleshooting before it goes to a pro, or lets me speak knowledgeably about what I'm expecting them to do, even if I don't want to do it myself.
Well, today we're going for another test drive, taking the trailer over to get the ball put on for the friction sway control. Then we'll be ready for the rally!
Stephanie
05-08-2003, 10:40 AM
Silvertwinkie
Spark plugs could be easier, especially on a car of that size. I hear on LT1 motors you have to remove the wheel and go through the wheel opening to get to some of them.
Which is why I like trucks. Full size ones are easier to service than either sedans or vans. On my 460, you can easily replace spark plugs and things that bolt onto the engine.
The easiest vehicle I ever saw was a full size GM truck with a smaller V6 engine. It looked like everything in it is a piece of cake. I think 5.7L is not much worse.
Pre-94 Caprices, with the L05 5.7L engine are somewhat easier to service than newer ones. First, you don't have to remove the water pump to access the optispark, and if the water pump breaks down, it doesn't flood it.
I originally wanted something with that super tuned LT1 'Vette motor, but then realized I was happy with the "regular" and older 5.7L TBI. I recently had the "9C1" motor installed from a '92 Caprice. So I now have a custom wagon, stock wagons ones never came with pre-'94 9C1 motor. Only gained about 20 horses however.
Contemplated using it as my towing vehicle, but I fear that even with 4.10 rear axle, the suspension wouldn't work. The power would be there, but doubling the towing capacity is questionable. (the manual recommends 5,000 lbs) And I am not sure I want 4.10 in my daily driving, probably bring your mileage down to 15-16 even on highway. So it would need suspension work, a heavy duty tranny, (4L80?) and still wouldn't be as good as a truck. I already have a heavy-duty cooling system. But I think that towing my A/S unit with that vehicle would fry the tranny pretty quickly.
Anyway. I too have some minor issues with my towing vehicle. Some kind of sensor, plan to pull the codes on it and checking what's wrong. Maybe this will help you?
Electronic Engine Control self test for Ford vehicles
05-08-2003, 11:44 AM
1959 22' Caravanner
Atlanta
, Georgia
Eric
Well of course you will never need to get at the filler neck. They don't break on a Chevy. Had to get a Ford poke in there.
Honestly I could see the hose connection being bad with age (course the one on my 70 Pontiac doesn't leak and it's the one it rolled off the line with) but how they heck does a filler neck "break" with out being involved in a serious wreck? Is it plastic?
1959 22' Caravanner
Atlanta, GA
