Old 05-06-2003, 06:40 PM   #15
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I looked it over this morning, but it was hard to see anything up there, and the whole driveway stank of gas, so I decided to run it down to the Ford dealer and let them take care of it. I know from restoring the mustangs, there is no job quite as nasty as one that gets you soaked with gas. So I left it to the pros. They called back and said the filler neck was broken, and they'll have it fixed and back to me by tonight or in the morning. I'll be another $300 poorer (the labor cost more than the part, probably just draining that tank to drop it and do the repair), but it's worth it to have it done right and not get my pretty little hands dirty. I spent the rest of the day getting the trailer ready to go. Much more pleasant.
Stephanie
Old 05-08-2003, 12:48 AM   #16
Stefrobrts,
Suggestions:
Get a "service manual", (Ebay is a good source)
use excellent resources such as
www.ford-trucks.com
Fuel systems can be really frustrating, they have gotten complex since carburator days.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 05-08-2003, 06:37 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
One nice thing about the Caprice is that the filler neck is easily accessed.
Now the spark plugs are a whole different story.......
Eric
Old 05-08-2003, 09:05 AM   #18
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Surprisingly, after taking two classic mustangs completely apart and putting them back together, the last thing I want to do when one of my every-day cars breaks down is work on it myself. Hopefully this one doesn't have anymore suprises in store for us. I will be getting a manual though. If nothing else it lets me do some troubleshooting before it goes to a pro, or lets me speak knowledgeably about what I'm expecting them to do, even if I don't want to do it myself.
Well, today we're going for another test drive, taking the trailer over to get the ball put on for the friction sway control. Then we'll be ready for the rally!
Stephanie
Old 05-08-2003, 10:40 AM   #19
Silvertwinkie
Spark plugs could be easier, especially on a car of that size. I hear on LT1 motors you have to remove the wheel and go through the wheel opening to get to some of them.
Which is why I like trucks. Full size ones are easier to service than either sedans or vans. On my 460, you can easily replace spark plugs and things that bolt onto the engine.
The easiest vehicle I ever saw was a full size GM truck with a smaller V6 engine. It looked like everything in it is a piece of cake. I think 5.7L is not much worse.
Pre-94 Caprices, with the L05 5.7L engine are somewhat easier to service than newer ones. First, you don't have to remove the water pump to access the optispark, and if the water pump breaks down, it doesn't flood it.
I originally wanted something with that super tuned LT1 'Vette motor, but then realized I was happy with the "regular" and older 5.7L TBI. I recently had the "9C1" motor installed from a '92 Caprice. So I now have a custom wagon, stock wagons ones never came with pre-'94 9C1 motor. Only gained about 20 horses however.
Contemplated using it as my towing vehicle, but I fear that even with 4.10 rear axle, the suspension wouldn't work. The power would be there, but doubling the towing capacity is questionable. (the manual recommends 5,000 lbs) And I am not sure I want 4.10 in my daily driving, probably bring your mileage down to 15-16 even on highway. So it would need suspension work, a heavy duty tranny, (4L80?) and still wouldn't be as good as a truck. I already have a heavy-duty cooling system. But I think that towing my A/S unit with that vehicle would fry the tranny pretty quickly.
Anyway. I too have some minor issues with my towing vehicle. Some kind of sensor, plan to pull the codes on it and checking what's wrong. Maybe this will help you?
Electronic Engine Control self test for Ford vehicles
Old 05-08-2003, 11:44 AM   #20
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Eric
Well of course you will never need to get at the filler neck. They don't break on a Chevy. Had to get a Ford poke in there.
Honestly I could see the hose connection being bad with age (course the one on my 70 Pontiac doesn't leak and it's the one it rolled off the line with) but how they heck does a filler neck "break" with out being involved in a serious wreck? Is it plastic?
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-08-2003, 11:55 AM   #21
Aluminut
2004 25' Safari
. , Illinois
I hear ya. My '80 Olds took 15 years before the tank started to leak at the seam.
Of course the "Dukes of Hazzard" manuvers probobly didn't help...
Eric
Old 05-08-2003, 12:35 PM   #22
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally posted by ipso_facto
Silvertwinkie
I was cursing my 454 burb a little changing the plugs Sunday. Looked easy enough to get at but fender is about 40 inches high and you have to lay over it and hang upside down to get at the plugs or ballance on your belly on the core suport. #7 I couldn't get a straight shot on because the shift linkage, Steering and brake plumbing was in the way. Did that one from underneath. #8 was a reach. Could get your hands in there between the Air pump blumbing and the A/C box but once they were in there you could not see so it was a brail job. Really not bad once I figured out the right combination of extensions and universals. Couldn't get a easy shot at it from below because of the exhast manifold shape.
Easiest I ever had 4banger water cooled VW's. all right up front pointed at you and nothing in the way. Wifes 4 banger accord is not so bad but a A/C line is a little in the way of #1 so starting the plug takes a little 3/8s fuel line.
My 75 350 Jimmy with a body lift and stands 7ft tall...I do it through the fender wells with long socket extensions...it's a peice of cake.
Now my Supra is a pain in the pututie! To get at #3 and #4 you have to take the throttle body off and the intake soft pipes. The intake runners are on driver side and wrap up and point over the engine with the throttle body hanging over the exust side valve cover. The air cleaner is on the passengerside behind the head light. Now pulling that engine is one of the easiest I have ever done. by myself I had it out in 1.5 hours with tranny. I am aware of a couple guys that fried a clutch at a SCCA event and did a clutch change in 1.5 hours by pulling the engine (It's easier to pull the engine then try to get hte tranny out and leave the engine in.).
As for the tranny question. THe 4l60 your car came with is a pretty good tranny. It's a lot better then the old 700R4. Put a big cooler on it and I doubt your going to have any issues as long as your not pulling more then an extra 6k.
3.73 gears would in reality be the same as a truck with 4.10 because of the tire size evening things up. You car probably runs a tire in the 28 inch tall range and a truck is about 31.
28 inch tall tire with 3.73 gears would be turning 2037RPM at 65mph in OD.
A truck with 31 inch tall tire and 4.10 gears is turning 2022RPM at 65mph.
http://www.ring-pinion.com/calculators.shtml has a good gear calculator you can play with.
1959 22' Caravanner
Atlanta, GA
Old 05-08-2003, 01:39 PM   #23
All this talk about vehicle repair reminds me - I am looking for another daily driver. My Caprice is nice but since I got the truck, I no longer need the towing package nor all the cargo space.
I've had good luck with GM products. I was contemplating something with the 3.8L engine like Buick LeSabre/Park Avenue but these are FWD probably more complex than RWD.
And, I wouldn't mind a 4-cylinder but I am not aware of any quality domestic ones which are not econoboxes. A manual tranny would be nice too.
I realize there are lots of quality foreign 4-cylinders but I don't want any imports, I like domestics because the parts are so cheap and everywhere.
Maybe I should get another Caprice, a sedan, with that smaller 4.3L engine (267 cid). I wonder if that, in conjuction with a lower rear axle of 2.73 will get me 25 MPG I want on the highway. (I currently get 21mpg.) Some told me this combo gets almost 30mpg, which is incredible for a V8.
Old 05-08-2003, 03:56 PM   #24
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I rented a new 6cyl Malibu and ran from Atlanta to Detroit. Decent power, handled pretty good, little torque steer from the front drive. A/C blew nice and cold the whole way. stereo was decent., Road respecatable. got 32mpg running 75mph with A/C. The only thing that drove me nuts is the OD kept hunting when I really felt it shouldn't have been.
1959 22' Caravanner
Atlanta, GA
Old 05-08-2003, 04:25 PM   #25
Chas's Avatar
Images: 22
Good looking van Steph!
I wouldn't mind having one myself but in a E-250 Powerstroke diesel. The Chateau editions are even sweeter, have a couch that turns into a bed but they are only available in the E-150.
What is with these chevy nuts taking over your thread??
Chas
Chas is offline   Reply With Quote
Old 05-08-2003, 05:55 PM   #26
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Ford, Chevy, Dodge, they all break down. When my Fords aren't broken, I'm working on the 68 vette :-) If it's not one thing it's another...
I took the rig over to my friend's house and he dragged his tools out to the street and moved the fricton control ball from one side of the tounge to the other so it would work with the hitch he sold me. In doing so, he had to cut through the old welds and grind them flush, and sparks were flying everywhere, including under the van. I'm so glad we found that gas leak before he did this job!
Stephanie
What's your tow vehicle's rating? John Community Polls 112 01-12-2009 11:13 AM
Top Ten tow vehicles ?? darkStar Tow Vehicles 34 10-19-2005 09:20 PM
More on tow ratings ipso_facto Tow Vehicles 19 11-16-2004 04:11 PM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
