Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-21-2011, 09:26 AM   #1
Bex
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I know its not an Argosy...
.........but I am not sure where to post this. Maybe an admin can move it to the correct place.
I saw this in a field a few miles from home. Could only make out the top from the road and thought it was a Travelux. So I waited till my son was with me and went to ask if we could look at it. In addition to this, the owner has vintage car (wrecks) and motorcycles galore. We spent almost an hour with the owner getting a tour. This trailer came off the hitch and got damaged so it was modified but too low on the back. They flipped the axel (or so I am told) to make it higher but now the wheels are tow out and it will not run in a straight line!
Project or not?
What year and model is it?
Name:	2011-08-18 16.09.43.jpg
ID:	138273   Click image for larger version
Name:	2011-08-18 16.07.43.jpg
Name:	2011-08-18 16.08.22.jpg
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 08-21-2011, 09:43 AM   #2
x
XXXX , XXXX
From what I can see quickly from the serial number it is a 1957 Overlander.
1957Overlander2_OH
wasagachris is offline   Reply With Quote
Old 08-21-2011, 09:48 AM   #3
Bex
I did wonder if it was from the '50's.
Not sure about the unit in the link, the back is not sloping.
TAC AB-1
Old 08-21-2011, 10:38 AM   #4
Baltimore , Maryland
those windows look much earlier than 57
Old 08-21-2011, 10:53 AM   #5
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
It has a flat rear end and bee hive clearance lamps on the flat sides. I think it is a 51-53 Flying Cloud. It is definitely a project!
Lance
Lance M is offline   Reply With Quote
Old 08-21-2011, 11:09 AM   #6
x
XXXX , XXXX
I think Lance has got it 53 FC.
53FC2
Old 08-21-2011, 11:23 AM   #7
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
That hurts to look at! So did they move the rear axle back as well? Then attached that old car frame to the front with another axle up there - and then expect to tow it? Very odd creation. Too bad because it looks pretty straight otherwise. Someone put a lot of work into messing that trailer up What did you see inside?
Stephanie
Old 08-21-2011, 11:46 AM   #8
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
It's a 53 Flying Cloud, but someone STOP Chris. Chris some are just not up to rebuilding.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 08-21-2011, 12:20 PM   #9
oh2bcarefree's Avatar
HOUSE SPRINGS , MO
Images: 48
I totally agree with Stefrobrts
Originally Posted by Stefrobrts View Post
That hurts to look at! ... Very odd creation... Someone put a lot of work into messing that trailer up.
Wow - what a lot of work to make that a mess. I would think it would take lots of hours and hours or money to pay someone to put it back on a proper frame - OUCH! Poor Airstream....
Tina
Tina and Mike
1959 Avion e-20
oh2bcarefree is offline   Reply With Quote
Old 08-21-2011, 12:54 PM   #10
x
XXXX , XXXX
You know Doug I hadn't given it any thought but I probably could graft the lower front end off the 63 O'lander on to that 53 FC and come up with a hybrid.
What year is that trailer?
Well It's a 1953/1963 Flying Cloud/Overlander. Or even a 1953 to 1963 Flying Overlander.
We can rebuild it. Stronger, faster a $6 million Airstream. Probably end up costing that much to do it.
Old 08-21-2011, 12:58 PM   #11
I say cut it up some more and turn it into a slide in...
Old 08-21-2011, 02:24 PM   #12
Bex
It was so full of junk that seeing was difficult, but they had of course made that front area a bed. Upper cabinets were there and as you enter, on the left side is a work top. Thats about as much as I could see.
I am in central Alberta and it was towed by the current owner from BC, where the accident/repairs(?) took place. Its been in this field for a few years.
Now that I look at it closer, I do see that the axle was moved back.
TAC AB-1
Old 08-21-2011, 02:38 PM   #13
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Lots of useable parts to salvage off a very old and hard to find unit but so far away. Sadly, this thing was probably in not so bad shape after whatever happened to it then the mods really screwed it up. I would have liked to of had this one.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-21-2011, 03:52 PM   #14
Bex
Its only 30 minutes or so from home. I wonder if its worth trying to get it off the Guy and salvage it?
Frank, would someone like yourself be interested in the parts and what might they be worth?
TAC AB-1
Old 08-21-2011, 04:18 PM   #15
summerkid's Avatar
1956 16' Bubble
Rose Lodge , Oregon
Hey, it's heartening to see someone's resto-gone-wrong after a steady diet of the seemingly effortless frame-offs here on the forum. Gives some of us hope.
Of course I'm an elitist. Look around you.
summerkid is offline   Reply With Quote
1993 30' (late 92 model) Excella :: 1993 Airstream Excella1000 arcamedies Airstream Registry Discussions 2 07-28-2012 09:10 AM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 08:32 AM
Elsa :: 1972 Argosy Argosy 20 bobfowler Airstream Registry Discussions 0 08-19-2011 08:31 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
