Old 08-04-2003, 09:20 PM   #1
infinite LUX's Avatar
i just bought my first "jug 'O' Walbernize"
okay, so I'm pretty excited about my new "stream"
after reading EVERTHING I could about Airstreams on this and SOF (some other forum) I went down to the local airtream dealer and bought a half gallon of WalberniZe. I read the instructions and, well, it seems to be the same sorta instruction you'd find on regular car wax
"1. Apply to surface using a clean, dampened wax applicator or cloth well saturated with WALBERNIZE, or use an orbital buffer
2. Apply with a firm even pressure to a small section (3'X3') using a circular overlapping motion
3. When a dry haze appears, buff with a clean soft cloth"
this is right off the bottle. Is this correct? I have a electric buffer. Can I use that?
db
(BTW, I can't wait to wax it, hehehe)
infinite LUX is offline   Reply With Quote
Old 08-05-2003, 06:38 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I dont think you need to bother with the orbital buffer. the stuff wipes off really easily w/ a terry towel. not like hard automotive wax at all. It really doesn't take long at all to do it. (PITA to get up on the roof, though )
Old 08-05-2003, 08:16 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Try to do the application in the shade or on a cloudy day if you can. It comes off so easily that a buffer would be a case of overkill. Be sure to shake the bottle well since it will separate. If you keep your trailer exposed all year, doing it twice a year will keep things looking good. My suggestion is in the spring before your first trip and before you put it away for the summer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-05-2003, 08:46 AM   #4
79 SLY
trumpwer's Avatar
Fairview , Montana
Images: 46
I have thought about WalberniZe, but my clearcoat is about 1/2 gone, lower 1/2. What will the Walbernize do on the unclearcoated area, should I even use it?
The Trumpowers
1979 SLY 31'
1979 GMC 4 door with s/c camper shell
trumpwer is offline   Reply With Quote
Old 08-05-2003, 11:47 AM   #5
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
it will seal the skin so it doesnt oxidize more. lol
al
wb13798 is offline   Reply With Quote
Old 08-05-2003, 12:13 PM   #6
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Follow the directions - buffer not needed
Maurice
Old 08-05-2003, 01:53 PM   #7
well....?
ok
I think I'll just use the towel....
but the instructions don't say that a buffer could be used for the wiping off
It says it can be used in the application. Does this stuff need to be rubbed in real good?
I'm thinking probably not, but may try a small section, applying it with the buffer pad, then wiping off by hand. As a test.
mucho thanks
db
Old 08-05-2003, 03:00 PM   #8
Tinsel Loaf's Avatar
I like the orbiral method of application and buffing. Even thought it's the easiest to apply and buff out of all the polishes i have used, I find that I blow out my arms and back doing the whole AS by hand. I orbital, how bout you?
Tinsel Loaf is offline   Reply With Quote
Old 08-06-2003, 08:52 AM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
I find it is so easy to apply and wipe off that a buffer would just get in the way. This stuff is not like creamy liquid car waxes, so its much like water in its consistancy.
If you have physical issues then do it with the buffer. I don't believe you will enhance your results by using one though.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-06-2003, 09:34 AM   #10
Silver Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Can Walbernize be used on other clear coat finishes (i.e. Cars & Trucks). If it so easy to apply, I wouldn't mind using on our other vehicles.
Thanks in advance.
Malcolm
kamadeca is offline   Reply With Quote
Old 08-06-2003, 11:39 AM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I tried the Walbernize product on one of my cars. Not great. Good quality car wax seems to work much better.
On the trailer, it seems to do the job well.
Uwe
www.area63productions.com
Just bought '76 20ft turbocharger All Argosy Trailers 9 11-27-2003 01:09 AM
Thor bought a SOB company? zduke4x Our Community 4 08-29-2003 08:09 PM
I bought an AS! now I need a carpet installer spinolio Airstream Motorhome Forums 0 05-01-2003 07:51 PM
5-year search ends. Bought my first Airstream! Silver Our Community 9 04-29-2003 05:35 PM
I bought an Airstream... now what? Swingking General Repair Forum 8 04-16-2003 07:52 PM
