Old 05-19-2012, 10:16 AM   #15
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
What is your method of massaging it open? This one seems pretty stuck. I have the side arms out, pull out the locking pin and put about all of my 185lbs into it. Is there a safe way to tap on it to loosen it? Can you tap from the base of the outer arm sleeve or is it better to keep working from the outside part at the awning roller?
CMSmith is offline   Reply With Quote
Old 05-19-2012, 10:37 AM   #16
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Got one side free, but the other is a bear right now
Old 05-19-2012, 11:06 AM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
argh - been a while and thats blurred together with eleventeen other things at the moment, your muscle memory is being programmed correctly about now I'd be willing to bet.. .
There is always the bend it over your knee trick as your hand cramps will allow for
Old 05-19-2012, 12:27 PM   #18
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
SUCCESS!!! With the awning, at least.
