Old 10-06-2017, 07:11 PM   #1
2013 28' International
Bozeman , Montana
Hoffman Architecture, Living Vehicle
Has anyone seen one of the Hoffman Architecture’s Living Vehicles in person? Although it is basically a box shape, the interiors are very clean and classy like their customized Airstreams. There are a lot of other things that I like including aluminum, not wood floors, VHB tape for wall construction, double pane windows, great insulation, etc.
Definitely not as towable as an Airstream but it sure would be nice for longer boondocking stays and the interior is killer.
I hope to be able to check one out in person this winter if we end up in Santa Barbara.
http://www.livingvehicle.com/
HeadWest is offline   Reply With Quote
Old 10-06-2017, 07:52 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Looks like a shiny tiny house on wheels. Nice design exercise.
MICHAEL
Old 10-07-2017, 01:50 AM   #3
Kent , Washington
Whoa.
DannyClark is offline   Reply With Quote
Old 10-07-2017, 06:42 AM   #4
Vintage Kin
Fort Worth , Texas
Towing that would be no fun at all.
"Sustainable" used as buzz word. Not applicable. Complete lack of aerodynamic design -- principles worked out nearly a century ago -- means a very high fuel consumption rate in a move (and that the tow vehicle be fuel inefficient by necessity). Kills any idea of comparisons to other rigs.
Lack of awnings or an equivalent means greater reliance on forced cooling. Etc.
Worse, with wheels recessed under walls -- thus a narrow track with weight attached to walls out side those -- it is more easily rolled. Wheel faces should have been outside walls to enhance stability. Huge design flaw.
As loss-of-control accidents are primarily about wind-handling, the only thing worse would have been this exact trailer as shown, but with leaf-sprung suspension.
Lack of radiused upper & lower side walls (plus low ground clearance) means wind pressure will build along the length of the vehicle with greatest pressure at rear. The wind cannot escape (with an AS the winds travel over and exert a "pull" rather than a "push"; a lesser effect). And as the suspension reaches wheel travel limits, this trailer will heel over, high ground clearance enabling that wind to also (at rear) get underneath. SOB particle-board TT performance at a yachtsman price.
Anti-lock disc brakes should also have been featured. No excuse for it.
It's a trailer that one moves from site to site. Not for travel in any meaningful sense.
Yet,
Gorgeous. Those folks know how to use photography.
Old 10-07-2017, 07:06 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
To me it has all of the charm of a commercial walk-in freezer.
Though I'll admit the fold-down porch and sliding glass door lend themselves to filling a previously unfilled niche in the market, namely handicapped-accessible RVing. Add a ramp to that porch, and you could have a fine wheel-chair accessible trailer.
On the other hand, lots of small commuter airplanes use fold-down airstair doors, so it would be entirely possible to put an entry porch and wheelchair ramp on the side of a curved trailer like an Airstream, if it was properly engineered.
Cats and ultraleather Airstream upholstery don't mix!
Old 10-07-2017, 03:10 PM   #6
2015 30' Classic
Pleasanton , California
Some things I really like about it:
1. A comprehensive boondocking solution: solar, lithium, inverter.
2. Comprehensive WiFi and cellular data solution.
3. Four season trailer with double-pane windows.
4. Options such as dishwasher and washer/dryer.
Competition is healthy and perhaps AS will step up their game in some of these areas.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 10-07-2017, 03:12 PM   #7
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Hitch weight spec’ed at 1,100 pounds. Wow!
Rocinante is our 2014 International Signature 27FB
Old 10-07-2017, 04:40 PM   #8
Kent , Washington
My 26U claims 900# and I'm at 1200# loaded. I want to know where they hid the lead.
Old 10-09-2017, 10:34 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Don't think that one is 1/2 ton towable...
It is very nice- very well appointed, very thoughtfully laid out.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-18-2017, 04:28 PM   #10
Santa Barbara , California
First and foremost, we at Hofmann want to extend our thanks to everyone who’s checked out Living Vehicle! We appreciate any and all feedback as it gives us a chance to address any confusion regarding our new product.
There appears to be a vitally flawed misperception of Living Vehicle’s intended purpose. We believe this is because airforums.com almost exclusively discusses Recreational Vehicles, and although LV makes a phenomenal part-time living and camping vessel, it is NOT an RV.
Living Vehicle is engineered to be a primary residence. Our guiding principles in designing this vessel were self-containment, self-sustainability, and full-time living capability. For instance, the angular shape, although perceivably less aerodynamic, allots more surface area for roof solar panels and allows the interior to resemble the four-walls-feel of a primary residence. It’s hard to feel truly “at home” in a tubular shaped structure where anyone over 6-feet is constantly worried about hitting their head upon entry.
Although its primary objective is to sustainably support full-time living, LV is designed by travelers and thoughtfully constructed with portability in mind. The Off-Road-Package increases ground clearance and strengthens the chassis and axles to industry-leading standards, improving capacity for heavy travel over steep grade changes and road types.
Off-Road Package Specs Include:
24” High Departure Ground Clearance
Four-Point 12V App-Controlled Stabilizers
Max CCC – High Capacity Axles
7” High Capacity A-Frame
15,000 # Bulldog Coupler
For more detailed information regarding portability, see the Specs and Features pages of our website.
What we’re excited about is LV’s off-the-grid capability. In its current version, Living Vehicle can already sustain 2 people living conservatively and fully off-the-grid for approximately 30 days. As these technologies for self-containment (solar/wind power, water-collection apparatuses, etc.) become cheaper and accessible for installation, LV's will be even more off-the-grid capable and less dependent on natural resources.
Living Vehicle is our contribution to providing a sustainable and intentional lifestyle. It’s a fully-functioning home that can take on the mobile demands of any lifestyle, all the while promoting a revival in the appreciation of elegant simplicity in our culture.
Learn more at livingvehicle.com.
bradrm00 is offline   Reply With Quote
Old 11-26-2017, 03:16 PM   #11
Macon , Georgia
bradrm00: Since you say, this is not a RV, I am curious, what market do you have in mind to sell to? I am guessing full timers, that rarely move from place to place?
Roadtech is offline   Reply With Quote
Old 11-26-2017, 04:13 PM   #12
DMP54's Avatar
2015 27' Flying Cloud
Jacksonville , Florida
Nice contender in the bourgeoning tiny house movement. Something for everyone...
DMP54 is offline   Reply With Quote
Old 11-26-2017, 09:09 PM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi - I see this is your first post here and you're part of the company referenced in this thread.
So - welcome to Airforums.
The pictures of your LV are outstanding and there are some exciting features. Your description of its purpose makes sense. The videos describing features and design ideas are compelling as well.
I am, however, slightly offended with the portion of your post quoted above for two reasons.
1) this is quite an assumption on your part, and insulting (unintentionally no doubt) to someone like myself, just under 6'2" who feels quite at home in my "tubular shaped structure" without worry about hitting my head. Such may be hard for you or your clients to feel at home, but that's not a universal story.
2) every product has a niche - I'm personally not a fan of positioning competition in the negative rather than extolling the features and benefits of your own product for buyers in that particular niche.
Those are my personal reactions of course and people's mileage can vary there.
Please have a look around and I think you'll find this to be a fascinating group of AS and Vintage Kin owners who are a very helpful community to fellow owners. I think you have the option of registering as a vendor/commercial user as well.
SteveSueMac is online now   Reply With Quote
Old 11-26-2017, 09:23 PM   #14
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
From what I've seen, I'm very impressed. I hope to see one in person, too.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Extreme RV TV show featuring Volkner Mobile & Hofmann Architecture walk0080 Airstream Lifestyle 0 06-27-2014 07:28 AM
Living in 34' AS Fulltime - Living My Parent's Dream.... bugnot1 Member Introductions 14 12-21-2010 08:40 AM
Architecture student wants to find out more about Airstream construction Oreo Interior Restoration Forum 12 09-28-2003 07:35 PM
airstream architecture Kira Our Community 0 08-21-2003 08:35 AM
