Old 05-11-2003, 12:30 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Hitch ball lubrication
Is it necessary to lube the hitch ball? I get dirty enough without that mess.
Kistler
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 05-11-2003, 12:36 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes
kistler
it needs lube, i use cheap wheel bearing grease.
i keep it in the tool box inside the tounge. along with the cheater bar for the hitch and some rags.
i got into the habit of diching the hitch when i get to my destination. avoids the mess and the walking into it and busting up my shins.
john
Old 05-11-2003, 12:50 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I use the Reese stuff in Walmart and when not towing I put a plastic cap over the ball to keep the stuff from getting on everything. I also remove the hitch and store it inside the trailer because I've done the same thing as John, busted a shin or tripped right over the thing in the dark.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-11-2003, 01:08 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
When I picked up my trailer the PO showed me his method. He places a five inch or so square of 4mil plastic sheet over the ball. It prevents friction, and keeps everything clean. He says he never uses grease, and he's been pulling AS for 20 years or so.
I'm not sure if it's easier than just smearing a little grease on the ball though.
Stephanie
Old 05-11-2003, 04:55 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Greese all the way!
Right now I'm using Mobil 1 synthetic greese. The same I greese my ball joints and rear control arm with.....
Eric
Old 05-12-2003, 09:32 AM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Teflon hitch ball grease
I use white teflon hitch-ball grease on the ball and on the equalizer bars. A plastic jar of it has lasted me for years.
It is great except for one thing ... it turns black in use and is sheer hell to get out of your clothes and off your hands if you accidentally touch the ball.
I usually remove the hitch when parked and lock it in the tongue. I put my locked pin through the drawbar to discourage theft.
John W. Irwin
WBCCI #9632
Old 05-12-2003, 10:40 AM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
This is an interesting topic. We did a technical forum at an April rally led by the service manager at Bill Thomas Camper Sales. One of the topics was lubrication on the hitch ball and on the trunion bars. He contended that the way most people lubricate these components actually causes more wear and tear. The important thing that most people neglect is keeping the lubricated areas clean. Most of the lubricant attracts dirt and other debris which end up grinding and causing wear and tear.
I took a look at mine and he was right. I probably would be doing better without the lube. I need to do some serious cleaning of the hitch components.
The other thing he noted was the number of loose hitch balls they encounter. Since the hitch ball is usually greasy and dirty folks tend to not check out the tightness of the nut that secures the ball.
I've seen the disks that are used on 5th wheel hitches that eliminate the need for lube. Would be nice if there would be a similar product for a ball.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-12-2003, 10:57 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am new to towing a car behind my motorhome, and have done it just a few times. The question I have is will greasing the ball help in getting the hitch off?
When we stop and want to get the car loose it seems to be awfully hard to do so. I have a Stowmaster and it is easy to use except for this.
I also have seen teflon hitch lube..any use?
Old 05-12-2003, 12:20 PM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
AlanSD,
You might want to make sure that your tow ball is the right size. It should not be unusually tough to undo the latch and then the ttrailer tongue should come off rather easily.
I am thinking that your tow ball might be too large for the trailer tongue, or tow bar mechanism, whichever it is you're using.
Uwe
www.area63productions.com
Old 05-12-2003, 12:48 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
consumable item
"The other thing he noted was the number of loose hitch balls they encounter. Since the hitch ball is usually greasy and dirty folks tend to not check out the tightness of the nut that secures the ball. "
i view the ball as an consumable item, when they get loose i have had little luck getting them to tighten up more. (or loosen)
just cut it off and get a new one.
20 bucks tops, cheap insurance.
john
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
Hitch Ball Height RivetED Hitches, Couplers & Balls 4 03-21-2004 08:25 PM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 04:56 PM
Hitch Ball size for 1971 31' Sovereign? westeagle Hitches, Couplers & Balls 2 12-07-2003 11:04 AM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
