Old 08-20-2003, 01:32 PM   #1
tjj's63's Avatar
1963 28' Ambassador
Orange , California
help! what size generator??
new owner here- taking our airstream out for her maiden voyage this weekend- unfortunately, there is no electric hookup to be had where we are going. what size generator should i get? i have a 1963 28' ambassador. i don't need anything fancy- i just want to be able to run the a/c off of it. any thoughts?
tjj's63 is offline   Reply With Quote
Old 08-20-2003, 04:05 PM   #2
gwsullivan's Avatar
There has been much controversy about this subject. According to Dometic's specification sheet you need the following size generator:
11,000 BTU -- 2.5KW Gen
13,500 BTU -- 3.5KW Gen
15,000 BTU -- 3.5KW Gen
I have read of people running their 11K BTU A/C with a Honda 2000 Watt generator but I have not personally tried it.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 08-20-2003, 04:21 PM   #3
1975 29' Ambassador
Reno , Nevada
interesting, all of these are single circuit appliances (15 amps 120 volts). What I get is that the starting currents are what set the requirements for genset output. And this makes sense.
The way folks power the AC with a Honda 2000i is by magic. First they get an easy start kit for the AC compressor that reduces start load requirements. Second, they make sure the AC is the only thing on the circuit when it starts. Third, they leave the AC on max cold so the compressor doesn't cycle. Even then it seems some need to start the AC only when the genset is cold.
What most people do is to use two honda gensets and run them in parallel, which you can do with some of the more modern inverter based gensets.
The 4kw to 5kw capacity generally serves most RV purposes.
Old 08-20-2003, 05:25 PM   #4
jtshipp's Avatar
Question What be dat.........?
.......... "genset?" Translate, please.............
jtshipp is offline   Reply With Quote
Old 08-20-2003, 05:37 PM   #5
LOST , Hawaii
Generator, because it is set of an engine and generator (or alternator).
John
74Argosy24MH is offline   Reply With Quote
Old 08-20-2003, 07:33 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Lots of folks have two Honda 2000i because of ease of handling
(around 50 lbs each) and very low noise.
One 2000w could put a strain on the AC comprssor and even cause damage that's why you don't want the start up load of the AC coming on and off. Some take the chance and run with one.
I have a 3500w with the 30amp 120AC output also 220AC should I need 220. However; it's heavy and not as flexable as the smaller Honda 2000i units.
Then again I paid $650 for mine with a 6hp Honda engine while the 2000i run $800 plus each.
Garry
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 04:39 PM
Dumb Generator Question #2 Dave-O Generators & Solar Power 8 07-10-2003 06:26 AM
Generator No Start jim8860 General Motorhome Topics 6 05-03-2003 04:43 PM
Installing a Honda 4010/6010 generator PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 03-06-2003 06:19 AM
Generator Good News I Hope Paul Daugherty Airstream Motorhome Forums 3 02-06-2003 11:15 AM
