Old 10-30-2014, 09:37 PM   #1
1984 34' International
Harrisonville , Pennsylvania
Help Thinking of buying
I am thinking of buying a 1984 34 foot international. It has not been used in about 6 yrs. Buying from an elderly widow so no history. Looks to be in good working order but in need of cleaning. I am a mechanic so repairs are no problem. I have never owned an airstream or even been in one before.
Any advice?
Things to beware of?
How much is it worth?
racer57 is offline   Reply With Quote
Old 10-31-2014, 06:49 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello racer57; We have a 86 Limited 34' Airstream. We find it very comfortable for long distance traveling. It weighs in the 8000 pound range with maybe 900 hitch weight. We pull it with a F-350 and before that an E-350 van.
I don't know of any major watch outs on the mid 80s trailers. One that has been sitting for many years might be full of mice, and might have hardened rubber suspension rods in the axles. Triple axles trailers have more side loading on tires, wheels and axles during sharp turns on pavement, which has been reported as a concern.
The oval "stack" windows in these trailers are known for internal seal failure between the dual panes of glass. Ours have failed and the windows are wet between the glass panes. We live with it for now. Pull the curtains and worry about something else.
Check that subfloor. If it's been wet due to leaks, it will likely have soft spots. The belly pan rivets tend to corrode holes in the belly pan aluminum. You can bet some of the appliances will need replacing. We are on our second water heater, second fridge, second furnaces (2), second air conditioner, third water pump. But the stove and oven are original in ours.
I believe the cabinetry in these top of the line Airstreams is very durable. Ours still looks good.
The aluminum is softer than the older trailers, meaning you will be prone to more dents. The clear coat is likely worn off due to sun and weather, so maybe stripping and polishing is in order.
Take a look at the Air Forums Knowledgebase toward the bottom of the home page. Find your model of trailer to get more specific information from owners. You might find it helpful.
Welcome to the Air Forums! I wanna know what you race...
David
New guy thinking of buying need help 1971 overlander nmex Member Introductions 15 07-02-2012 01:30 PM
Thinking of buying an older Airstream Old Cracker Member Introductions 7 11-20-2006 10:25 PM
Thinking of buying a 75 Argosy 24' Motorhome hamilton1965 Trailer Values 8 03-28-2006 03:57 PM
I am thinking of buying: is it worth it? JeffTerry 1981 - 1983 Excella 12 02-19-2006 11:10 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
