Old 09-23-2003, 11:14 AM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
help ID this vintage
There's a vintage AS (I think) near us, parked way out in a field by an old barn. I can't get a close look at it, but it looks about like my Caravel, with basically the same window layout, a small window curbside towards the back and two windows streetside, and it has a 'door within a door'. It also has a wide burgundy stripe down the sides. From these clues can we guess what vintage it is?
Stephanie
Old 09-23-2003, 12:28 PM   #2
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
hey steffy....
why dont you do a stealth, and climb over the fence?
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-23-2003, 12:40 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Is there a prize for the correct answer?
More clues pleez.
Rog
Rog0525 is offline   Reply With Quote
Old 09-23-2003, 12:54 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I believe '64 was the last year for door-within-a-door in smaller trailers like Bambis & GlobeTrotters. My intial guess would be a '62 GlobeTrotter...check out the second one on this page...whadda ya think?
Bambi's don't have the curb side windows...and they have that "mini-window" in the back.
I agree...some pictures would help.
Shari
Old 09-23-2003, 12:58 PM   #5
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
"Door within a door" says it's pre-1963 model. If it's really about the length of your Caravel, it could be a Globetrotter (19 ft). Some of them came with single curbside window, others with double, according to RJ Dial's website .
The stripe is a surprise but you never know what people will do over the years ... The 1980 Caravel had a red stripe like that, but you can easily tell it's not vintage.
rluhr is offline   Reply With Quote
Old 09-23-2003, 12:59 PM   #6
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Well, Shari and I posted at the same time and came to the same conclusion! 1962 Globetrotter -- let us know if we're right!
Old 09-23-2003, 01:00 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
rluhr
S~
Old 09-23-2003, 02:54 PM   #8
Correction re: Doors
My '63 has a "door within a door," and Shari's '64 does, too. Not sure if they were made any later than that, though.
Tom
63flyingcloud is offline   Reply With Quote
Old 09-23-2003, 03:02 PM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
Where's Fred???
Luke & Donna's Caravel is a '65 and it doesn't have the door-in-a-door. I seem to recall Fred mentioning that '64 was the last year for the two doors...
From looking at the archives earlier, it appears some pre-64 trailers had door-in-a-door and some had jalousie windows within the door, even the same models, one would be one way & the next the other...I wonder if this was a CA vs OH thing or just an option and you could get it either way?
Shari
Old 09-23-2003, 03:43 PM   #10
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
door with in a door
I've actually been working earlier today. 1964 was the last model year for the door-within-a door. In 1965, Airstream went to the full size (length & width) solid door on the large cast hinge with a full size screen door behind it. Without having scoured RJ's Photo Archives, the only trailer I recall with a louvered window in the door itself is the 16' Bambi. The earliest Bambis ('61 & maybe '62) sometimes had the door-within-a-door, but most later Bambis (62 & 63) had the louvered window in the door, as it was often the only curb side ventilation available. Larger trailers may have had louvered windows just in front of the door-within-a-door. I've never looked to see, but were louvered windows ever installed in 1965 and later trailers that had the full size screen door?
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 09-23-2003, 03:56 PM   #11
RJ's 1965 Caravel has Jalousie windows in the door. His website says they were an option that year.
Tom
Old 09-23-2003, 05:10 PM   #12
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
We drove around it about three times, taking pictures from the different sides, and this is the best we got. It's awful, I know. You can see there's a rooftop AC unit, and a fridge vent right in front of that. There's an awning. There is a curbside window right above the fence post. The burgundy stripe goes over the door. It is a door within a door, but no jalousy window (I think). This was with the telephoto lens. It looks like one of those awful car & driver spy photos. Darn cow wouldn't get out of the way!
The street side looks much like my Caravel, except I'd say the windows look bigger/take up more space across the body. The road on that side of the property is much further away, couldn't get a good shot of it at all.
Stephanie
Old 09-23-2003, 05:19 PM   #13
The truth is out there...
And if you look REAL close, there's a flying saucer in the upper left corner.
Nice photo, Steph! That's a COW???
Old 09-23-2003, 07:12 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
The UFO was so obvious, I didn't feel I needed to point it out...
Stephanie
Vintage sub-units? Midamrail WBCCI Forum 47 12-10-2006 09:53 AM
Vintage vs. "other" trailer Steve-O Trailer Values 15 01-08-2004 11:49 AM
Vintage Minitrailers babycakes Our Community 13 12-12-2002 04:46 PM
How vintage is vintage? zamboni On The Road... 9 12-02-2002 04:30 PM
Vintage trailer rally 83Excella WBCCI Rallies & Events 0 08-13-2002 10:27 PM
