Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-17-2002, 06:45 AM   #1
Sharon Lee's Avatar
Question Help find the weight of a 1981 31foot Excella
Hello!
We need info on how to hook up our truck (1996 GMC Suburban K1500 with tow pkg.) to pick up a 31 foot Airstream. What size 7 plug hole for the electrical hook up do we need for a 1981 Excella 2 Limited, What style brake controller do we need? AND- If anyone has the approximate weight of an 1981 Excella.
Any tips on just beginning HELP!!!
Thanks Alot-Sharon and Sean Lee
Sharon Lee is offline   Reply With Quote
Old 06-17-2002, 08:28 AM   #2
1996 30' Excella
Brighton , Michigan
Sharon,
What type of plug is on your truck? or does it just have 7 wires? What type of plug is on the trailer? It orginally had a 7 or 9 round pin connector I believe, but may have been changed to a flat 7 way connector.
For a brake controler I perfer the Teknosha, as it is the smoothest and is easy to adjust.
I had a 31' '81 Excella II for several years. If I remember correctly the trailer gross weight rating was 7100 lbs and it dry weight was about 5600 lbs.
apple 1 is offline   Reply With Quote
Old 06-17-2002, 12:41 PM   #3
Sharon,
Bear with me. I have my manual in the AS, which is parked in storage. I'll get it within the next couple days, and if you have not had a response, I'll advise you. I do know, however, that the GROSS wight for the '81 Excella Limited is around 8500 pounds. I'll add more later.
Jack Kleven
1981 31' Excella Limited
jkleven is offline   Reply With Quote
Old 06-18-2002, 06:01 AM   #4
Sharon Lee's Avatar
Smile
Thanks for the replys. We figured it out The suburban goes in on Thursday to get checked over and to get it all set up to buy and pick up our new(old) Airstream.
Hey does anyone know if a K1500 GMC Suburban 350 engine with tow pkg. be o.k. for pulling a 31 ft. Airstream or are we in for it?
Thanks, Sharon Lee
Old 06-18-2002, 08:37 AM   #5
83Excella's Avatar
1983 27' Excella
Airstreamville , Kansas
There should be a tag on the left front lower panel with the empty & gross weight on it.
John
83Excella is offline   Reply With Quote
Old 06-18-2002, 12:56 PM   #6
Sharon, your Suburban should pull the 31 footer just fine. If you got your wiring and brake controller thing figured out, I guess you have a weight distributing hitch too. Hopefully you have access to somebody that knows about these hitches to help you properly set it up. With a trailer that long, the air off passing trucks and buses may cause the trailer to sway. If that should be the case, you will want to look into some kind of sway control device before you start your tour around North America.
We towed a '98 31 footer with a 99 Tahoe for a couple of years. That trailer weighed 7,000 empty with an 8,300 max. I don't know if your trailer weighs the same or not.
Good luck, be careful, and have fun!
Regards,
Lee
LeeC is offline   Reply With Quote
Old 06-18-2002, 03:55 PM   #7
83Excella's Avatar
1983 27' Excella
sway control
You will definitely need sway control for a trailer that long.
John
Old 06-18-2002, 07:48 PM   #8
Sharon Lee's Avatar
Smile
Thanks again for the info. The trailer comes with everthing to tow it with, so we should be set! We can't wait to see it. We pick it up June 28th so Im sure we will have more questions in the future.
Until Then- Sharon and Sean Lee
Old 06-18-2002, 08:55 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The new www.airstream.com site lists the 1981 Excella Limited 31'rear bath at 5500 lbs. dry wt. and 720 hitch wt. The center bath is 5500 and 725 respectively. Craig
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Questions-31' 1981 Excella Sharon Lee 1981 - 1983 Excella 8 09-03-2011 06:56 PM
'87 Excella weight odfarley 1987 - 1989 Excella 2 10-27-2005 02:05 PM
1981 Airstream Excella diesel motorcoach jenia@mundomotors.com Airstream Motorhome Forums 1 03-21-2004 05:11 PM
Towing 1981 31' Excella redlion7 On The Road... 4 11-11-2003 01:15 PM
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
