Old 10-18-2016, 01:05 PM   #1
trigal's Avatar
2016 25' Flying Cloud
Celebration , Florida
Heat pump question
Is heat pump to drain through same drain as air conditioner? I realize HP is reverse of AC. Thanks
trigal is offline   Reply With Quote
Old 10-18-2016, 01:15 PM   #2
dznf0g's Avatar
Oswego , Illinois
No, the heat pump drains out onto the roof.
-Rich-
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 10:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
