Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-17-2003, 02:37 PM   #1
Dave Jenkins
Profile:  2004 28' Classic
Kenney , Texas
Ham radio question: installation of 2m/70cm antenna in Classic 28'
We would like to install a short dual-band antenna in a 28' Classic. Since this trailer hasn't been built yet, we are considering asking A/S to install the mount at the factory, with the radio end of the coax terminating in the same compartment where the normal fm radio antenna comes in.
Is this feasible? Does A/S do modifications such as this? Where would such a mount be grounded?
We really don't want the hassle of setting up tripods and antennas when we stop. I guess if push came to shove we could use a glass-mounted antenna, but I really don't want to see the coax running through the lving area. (If push really came to shove, I guess, I could always go up to the pickup cab to talk, but I'd rather not.)
Anyway, if anyone out there has experience in this area, we'd love to hear from you.
Dave Jenkins
K5KX
Dave Jenkins is offline   Reply With Quote
Old 08-17-2003, 03:05 PM   #2
drboyd
drboyd's Avatar
Profile:
My trailer has a CB antenna...
....mounted on one of the metal vent covers. The wire is fed down thru the airconditioner, and over to a partition.
One of the previous owners did it, probably themselves...
Old 08-17-2003, 04:16 PM   #3
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Don't forget to have them run a 10 gauge power and ground wire to the radio location as well!
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 08-17-2003, 06:47 PM   #4
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
The 2004's we saw on the factory tour have a new radio antenna which looks like a "rubber ducky" style and exits through the top of the coach (*see pic). Unfortunately we didn't get a good look at one to see what sort of mounting it used.
If they would allow it, you should ask them to run an extra coax for you. That would be really slick to have a built in NMO mount from the factory. Somehow, though, I fear they may not jump up and down at that idea!
If so, a lot of hams use the refridgerator vent cover as a convenient place to mount a 2m/440 antenna. You can use the area behind the fridge to run the coax and enter the coach at a convenient spot out of sight behind a cabinet. I used a Diamond multi-angle adjustable NMO style trunk lip mount to mount to the refridgerator vent cover. Even with a short dual-band antenna, it's more than adequate for simplex at a rally site or getting into a local repeater.
-Dallas (KB9QPE)
Name:	stubby antenna.jpg
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 08-17-2003, 06:58 PM   #5
odfarley
odfarley's Avatar
Profile:
Wink 2 meter ham ant.
My 87 Excella has a 2 meter ant mounted on the metal vent cover over the ref. and coax fed to the inside.
Both me and my wife are extra class hams.
Good luck
WD4SCL & KC4BMK
O.D. Farley
1987 Excella 32ft \ Equal-i-zer Hitch
2500 HD Chev Tr. 2003
WBCCI # 13524
odfarley is offline   Reply With Quote
Ham Radio in A/S 53flyingcloud Phone, CB & Ham Radio 209 10-05-2008 10:48 AM
A Classic Question? da moose Airstream Motorhome Forums 5 01-27-2004 06:43 PM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
