Old 11-15-2014, 08:37 AM   #1
gomotomoto's Avatar
Longport , New Jersey
Half polished. Half arsed....
We bought our trailer with a pretty lame polish job. In all fairness, it was covered in graffiti when the previous owner purchased it and they were most likely happy enough once it was semi-shining with the rattle can paint off of it. It looks ok from a few feet away, but you can tell they only did one pass with a polishing tool, probably a grinder with a polishing pad by the looks of it.
At night, when a light is shining on the airstream, you can see it was an amateur job at best, so I'd like to go over it and do it right.
I'm not so sure I want to invest 200 hours of my time and don't necessarily want it mirror finished. I just want it clean with a nice appearance. I actually prefer it to have a little less shine. Perhaps on the matte side. I don't mind mirror -- but not enough to take a 3rd or 4th pass to achieve it.
What's the best way to go about it? It's dirty & had a marginal polish done about 5 years ago.
gomotomoto is offline   Reply With Quote
Old 11-16-2014, 08:52 AM   #2
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
You might be seeing the swirl marks from the PO using a compounder or other rotating machine. Part of the approach may depend on the year of your trailer. Pre-1969, Airstream used a different (Alclad) aluminum sheeting. The early trailers give a mirror finish better because of the 5 mils of pure aluminum on the surface of the Alclad. You may want to make one pass with a finer polish and a Cyclopolisher. Because of the orbital nature of the Cyclo, it doesn't leave swirl marks. A less expensive approach may be to use an inexpensive orbital polisher or orbital sander, with a wool bonnet and a bottle of truck box polish from Lowes for that pass. If the swirl marks aren't too deep, this may work for you.
Good luck,
Roy and Marie
64airstream is offline   Reply With Quote
Old 11-16-2014, 09:37 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
There is no fast and easy method of a good polish.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-16-2014, 10:10 AM   #4
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Sounds like you're seeing all the swirl marks at night from the compounding. How about some pictures?
Try googling how to polish an Airstream. Lots of different methods all require some pretty good effort and the right equipment. I'd try one more pass compounding the trailer and one with a Cyclo or similar swirl removing tool. Stop when you're happy with look.
Warning it is addicting when you see it really start shining up.
desertair27 is offline   Reply With Quote
Old 11-16-2014, 02:42 PM   #5
gomotomoto's Avatar
It cleaned up pretty good actually. The truck box Polish did a decent job but I think it will need a little more grit to clean out the spots.
Most of the trailer had an attempt to polish, so I think I have a head start.
Here's a pic:
Name:	ImageUploadedByAirstream Forums1416174125.654371.jpg
ID:	226690   Click image for larger version
Name:	ImageUploadedByAirstream Forums1416174138.548029.jpg
Old 11-16-2014, 03:47 PM   #6
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Lookin good
Old 11-17-2014, 11:41 AM   #7
1964 22' Safari
1968 26' Overlander
And it begins... Looks like she will shine up pretty well, but note that each year you'll probably want to give it one pass. The more protected your storage the less work that requires each spring, but it's still a lot of work. Your trailer looks like a '64 (long one), so it is Alclad.
Couldn't help notice how deep the rear bumper is. With the rack/rail it could almost be a back deck...
We hope you enjoy the immediate feedback your polishing effort affords you more than you dislike the work.
Roy and Marie
Old 11-17-2014, 11:44 AM   #8
gomotomoto's Avatar
Roy and Marie
Haha! I actually don't mind it! It's just that it moves so sloooooooooooooooooooooooooooooooooooowwwwwwwwwwww ww!
I have some nuvite on the way, so we will see
Old 11-21-2014, 04:02 PM   #9
gomotomoto's Avatar
Well .. Totally worth it! The nuvite seems to work like a charm. Just did one panel, but it looks incredible!
Old 11-22-2014, 04:41 AM   #10
1964 22' Safari
1968 26' Overlander
You know you're hooked when...
No more trips to the gym for upper body workouts.
Dedicated clothes for polishing.
Portable scaffold for better access to high areas.
New bigger scaffold to reach the roof, even though nobody sees it.
Collection of wool bonnets too dirty for the washer.
Searching fabric stores for 100% cotton sweatshirt material.
Enjoy,
Roy and Marie
"Heavy-Half Ton" Pickup Trucks hex Tow Vehicles 7 05-02-2013 12:49 PM
Had a "half vast" Idea... Foiled Again Off Topic Forum 6 12-09-2005 07:31 PM
Half Ton Truck w/ 32' ('89) Excella? Boaz1362 1987 - 1989 Excella 26 11-30-2005 07:41 PM
Polishing almost half done already! drboyd Cleaning, Stripping & Polishing 39 10-14-2004 10:09 AM
Looking:photos of half-circle dinette?? johnboy General Interior Topics 4 07-30-2004 11:18 PM
