Old 12-29-2005, 07:47 AM   #1
FiveGreers's Avatar
Crestview , Florida
Going to look TODAY @ a 77 Trade Wind...HELP....
My parents are going to look at a 1977 Trade Wind for me today. They have a 2000 Excella, so they "know" Airstreams. BUT, I'd like to hear from you all about what they can/should look for in this older unit.
All comments/suggestions are appreciated!
Thanks-
Minya in Florida
(trying hard to contain my excitement!!!!!!!)
FiveGreers is offline   Reply With Quote
Old 12-29-2005, 08:27 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Thanks-
Minya in Florida
Congratulations!
They should look to all systems for functionality. Interior should be complete and functional, with no signs of water leaks. Inspect the belly and axle system real well, to see if th eunit was flooded during the recent hurricanes.
Poke around the perimiter of the floor, making sure there are no rotten areas. Especially around the entry door, and underneath the front/rear windows. Plumbing and electrical systems should be checked.
I would worry less about a flaking clear coat ( normal) or a weak battery ( cheap to replace)
Look at tires and brakes, and check the axles. ( use the forum search function for axle check) Try and get a receipt from the owner when the bearings were serviced last, or just have a trailer service do it just in case.
Inspect teh skin for damage and/or popped rivets. Make sure teh windows all open and close properly, and that there are no leaks on the eyebrow windows up above ( if so equipped)
Inspect roof vents for missing or broken lifters, and for cracked lids.
Look inside the cabinets and under the bed/couch. There should be plastic bins as drawers in there. Same in the dressser ( if equipped)
Good Luck, and Happy New Airstream Year!
Uwe
www.area63productions.com
Old 12-29-2005, 08:42 AM   #3
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Kinda depends on the price they want for the unit as to what you are willing to live with; however, I agree that the floor and the axels are a big item. These things are expensive to replace. The A/C is also important if it is original to the trailer. It probably won't last long for you if it has been up there all these years. That's about 5 to 8 hundred to replace. The frig. needs to work because that is also an expensive item. It takes a while for those old units to get cool, so your parents may have to turn it on and then do their inspection. Some things you can live with like the lights not working or the upholstery worn. Even the peeling vinyl wall covering is an easy fix. Check the fresh water tank for leaks and see if the pump works. Pumps are not expensive, but rewiring is, so get suspicious if none of the lights AND the pump won't work. Of course rust is a big worry for old costal trailers, so look at the frame as much as possible and the shocks and axel for this. We're all excited for you. Hope it turns out to be a great trailer.
juel is offline   Reply With Quote
Old 12-29-2005, 09:00 AM   #4
FiveGreers's Avatar
Crestview , Florida
Thanks!
They are getting ready to head out so I cut and pasted your responses in an email to them. I'm not attaching myself to this camper, as if all looks/smells good, I'll offer them less and see what happens. I appreciate the info, and if it DOES work out, I know I'll have a TON more questions- !
Old 12-29-2005, 09:32 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Thanks-
Minya in Florida
Good luck! Check out my site, been restoring a 75 Tradewind!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 12-29-2005, 10:00 AM   #6
FiveGreers's Avatar
Crestview , Florida
I checked out your site when I first started looking and thought to myself "wow, I wish I could do something like that!" You've done an outstanding job! It looks fantastic!!
I called my parents and they're not there yet. So funny-she said she gave me til noon to call, and I called 11 minutes earlier- ! LOL! I have our little neon flamingo lit up for good luck! BUT, it not this one, then there will be one for us, I just know it! I'll post back once I hear from them.
Old 12-29-2005, 10:19 AM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Got my fingers crossed for you
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 12-29-2005, 10:20 AM   #8
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
The suspense is too much. Let us know as soon as you can. I remember waiting to see my "new" 78 Argosy. It's so exciting. I know what you are feeling. You don't want to get attached, but you can just picture yourself camping in it. Good Luck.
Old 12-29-2005, 01:09 PM   #9
FiveGreers's Avatar
Crestview , Florida
The search will continue...
This wasn't the one for us. They said there were a lot of things not to great about it and for that price, it shouldn't have needed that much renovations. That's okay, it wasn't meant to be! I'll continue to look-although they said there was a really cute 2004 Bambi on the lot-lol!
Thanks for all the help and cheering! We'll find ours one day-and you can count on me continuing to look!!
Old 12-29-2005, 02:39 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Not only look at the axles to determine negative axle deflection but also look at the frame where it comes out from the rear axle and heads to the rear of the coach. It should not be twisted but be straight as an arrow. Take a look at the outside skin for waves or bulges near the middle of the coach by the axles because this may also be a sign of rear end sag. You might also see this on interior trim near beds if you have a rear bath/mid twins.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-29-2005, 03:12 PM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Been there! Sorry to hear about the bad deal. Hope you didn't travel too far to be let down. Hang in there, you will find the right one. I have never regretted the trailer I walked away from, and I love the trailer that found me!
Richard
Old 12-29-2005, 03:53 PM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Keep lookin, you never know where one will pop up!
www.balrgn.com
Old 12-29-2005, 04:10 PM   #13
FiveGreers's Avatar
Crestview , Florida
LOL-as I'm a "pop up" camper right now- ! Cute!
Old 12-29-2005, 06:42 PM   #14
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Bummer!
'59 Trade Wind flyfshr 1959-69 Tradewind 196 03-10-2013 09:42 PM
Manual for '72 Trade Wind igor 1970-79 Tradewind 10 05-04-2005 09:55 PM
Trade Wind Eyebrow Windows uwe 1970-79 Tradewind 6 07-17-2002 09:10 PM
'72 Trade Wind Pigtail Schematic igor Brakes & Brake Controllers 3 07-14-2002 03:15 AM
repair 1978 Tradewind Pam1 General Repair Forum 1 06-21-2002 08:28 PM
