Old 06-10-2015, 05:22 AM   #1
gomotomoto's Avatar
Longport , New Jersey
GFI protection for older trailers
What does everyone do for GFI protection with older airstreams?
gomotomoto is offline   Reply With Quote
Old 06-10-2015, 06:38 AM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Don't have an older trailer but if possible you could replace the circuit breakers in the main panel with GFI breakers. In a house the normal application is to wire in a GFI outlet at the first location in a circuit thereby protecting all the downstream outlets.
kscherzi is offline   Reply With Quote
Old 06-10-2015, 06:28 PM   #3
gomotomoto's Avatar
Anyone use one of these:
http://m.campingworld.com/shopping/i...otection/74402
Old 06-12-2015, 11:04 AM   #4
Sioux Falls , South Dakota
I have a Progressive Industries unit that is similar to that one. I chose PI over Surge Guard because the PI unit is made in America, while the Surge Guard one isn't. PI also has a lifetime warranty.
As for putting in a GFI, if you have three-wire outlets already you can simply replace an existing one with a GFI one. If that is the first outlet on the circuit everything else on that circuit will also be protected. Many coaches use an outlet system that is a bit more complicated than typical household items, so you may need to go to an electrical supplier rather than Wal-Mart to get the proper item. As long as your exterior outlet(s), bathroom and kitchen outlets are GFI-protected you are safe.
This would be a good time to inspect all of your 120V wiring.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Tanks Level Gages on older trailers perryg114 Waste Systems, Tanks & Totes 10 02-12-2014 03:12 PM
MSRP of older trailers StevenG Airstream Trailer Forums 10 07-08-2013 09:46 PM
Filiform - only newer trailers or older too? Soyboy Ribs, Skins & Rivets 11 10-05-2008 10:36 AM
A/C Blows GFI in Home Jenturnr Our Community 3 07-27-2004 07:39 PM
Gfi markus Electrical - Systems, Generators, Batteries & Solar 4 01-28-2004 08:23 PM
