Old 09-08-2003, 08:10 PM   #1
dlorahcof's Avatar
Question Front gravel guards
Does anyone know how to remove the ugly white stuff from the SS front gravel guards on a new A/S?
Trying to start the corner to peel, it just comes off in little pieces and flakes.
Book doesn't give a clue and AS dealer couldn't even get the stabilizer jacks to work.
dlorahcof is offline   Reply With Quote
Old 09-08-2003, 09:42 PM   #2
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
not sure if this will help or not...but try GOO GONE...its in the paint dept at the home depot....good luck...
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-09-2003, 09:18 AM   #3
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
This is what A/S told me to do
My rig had been sitting on the dealers lot almost a year when I bought it, so the film was almost cemented to the stainless steel. Anyway, I called A/S tech support and after telling me that the dealer should have removed it, they then told me to use a heat gun and patience. It took me an entire day to remove the stuff. I used a commerical heat gun. I would heat an area about the size of your hand until I could see a bit of bubbling up (not scorching), I then took a hard plastic spatula and carefully removed the released film. The key to heating the film is to never leave the gun pointed at any one spot. I used a circular motion to heat the area. Sometime I got lucky and a much larger section would peel away. After I got all the film removed, I was told to use some laquer thinner to remove the adhesive that might remain (care not to splash any as it will remove clearcoat and paint as well). BTW, the stone guards are not clearcoated as stainless steel needs no such protection. Not really difficult, just time consuming.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 09-09-2003, 10:41 AM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Re: Front gravel guards
Good Grief ! Your DEALER couldn't get the jacks to work? What in the world are you going to do when you need serious repairs? !!!!!
Roger
Old 09-10-2003, 10:49 AM   #5
dlorahcof's Avatar
The heat gun idea sounds pretty good!
The unit has been sitting on the lot for about 6 months.
As to the dealer.
They were the only one in TN and were being started by the Mitsubishi dealer. Guy on lot was a former car salesman and doesn't have a clue about RVing.
Repairs will be made by a rep at the FORD dealer (not in my lifetime). I will have to take it to AS since the people here didn't
even know how to prep for delivery. That part goes on to AS.
BUT!! I've got the AS and am looking forward to a different style after 10 yrs of diesel pushers.
Thanks to all for the advice.
WANTED: Front Dinette Photos InsideOut General Interior Topics 21 01-12-2007 03:09 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Front dinette overlander63 All Argosy Trailers 7 08-12-2003 08:47 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
