Old 06-17-2016, 08:27 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Fresh water drain
Water draining at a slow rate from drain between tires. I put a piece of plastic tube in drain, blew and some black mold/moss can out. Water then drained. Filled again and same thing happened. Ran 6 ozs Clorox thru, same result. Anyone know what this stuff is and how to get rid of it? This is a new 2015 FC 28.
DeltaRon is offline   Reply With Quote
Old 06-17-2016, 08:45 PM   #2
1991 25' Excella
Stanfield , Oregon
There should be instructions in your owners manual for sanitizing your fresh water tank. Personally I pour in 5 gallons of bleach and then fill the tank with filtered water. Before a trip then drain and flush once im there.
SpletKay06 is offline   Reply With Quote
Old 06-17-2016, 09:13 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
5 gallons of bleach sure sounds like a lot.
CRH is offline   Reply With Quote
Old 06-17-2016, 09:36 PM   #4
1991 25' Excella
Stanfield , Oregon
The chart I used was completely wrong but oh well. At least its clean.
Old 06-18-2016, 03:03 PM   #5
DeltaRon's Avatar
Cumming , Georgia
Fresh water drain
Thanks for all the comments, but does anyone know what this black stuff might be and how to get rid of it? I've sanitized 3 times with Clorox.
Old 06-28-2016, 06:05 AM   #6
Long Island , New York
Assuming the new trailer is still under warranty, I would insist that the dealer replace the tank, after first finding out the source/cause of the black gunk.
And yes, 5 gallons is way too much bleach. I usually put about a cup of bleach diluted into our 20-gallon fresh water tank. For shocking possible unhealthy mold etc., the ratio should probably be higher, but I would not go more than 1 gallon of bleach per 20 gallons, and I would not let this concentrated solution sit in the tank -- or water heater especially -- for longer than an hour plus or minus.
Be sure to run the bleach solution through all the plumbing lines including outdoor shower, etc..
And obviously rinse rinse rinse multiple times . . .
There are lots of threads here which discuss this issue.
For instance:
http://www.airforums.com/forums/f444...ks-148438.html
http://www.airforums.com/forums/f240...nk-139845.html
If you use the Search menu link above right, the Google search in the middle of the pop-down box works best.
Good luck!
Peter
Old 07-23-2016, 02:34 AM   #7
Wondering if you got this sorted out, and what the black stuff turned out to be?
Peter
Old 07-24-2016, 05:41 AM   #8
DeltaRon's Avatar
Cumming , Georgia
Fresh water drain
Still don't know what black stuff is. After cloroxing 4 times, I don't see anymore of the stuff and water drains ok.
Old 07-24-2016, 05:44 AM   #9
Thanks for the reply. Hope it all works out OK!
Happy Trails . . .
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
fresh water drain: broke it off. help jparks Fresh Water Systems 12 10-07-2009 06:20 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
