08-17-2008, 07:56 AM
2007 25' Safari FB SE
Dexer
, Michigan
Flooring lifting around toilet? Looking at a used AS...
Hi,
Went to look at a 2005 Safari 25'. All looked nice until I noticed the laminate flooring was lifting all the way around the platform that the toilet sits on. I'm thinking that can't be good.
Any thoughts?
08-17-2008, 08:14 AM
2002 25' Safari
Dewey
It might have got wet and is now puffed up. Laminates use particle board as a base with the top laminated with the wood look. They will swell if water gets into the base. It will need to be replaced if this has happened.
Richard
08-17-2008, 09:53 AM
Trabuco Canyon
I had a couple edges of the flooring which curled up about a quarter inch-and I glued it back down. Possibly if I hadn't it would have continued to pull away. But if its happening extensively I'd check for leaks.
08-17-2008, 11:28 AM
418
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Sometimes water splashes out of the toilet while towing, even when driving carefully. It could be just that. However, before buying, i would insist that this be checked thoroughly.
08-17-2008, 12:52 PM
Dexer
, Michigan
Thanks everyone. We are thinking they are asking a bit much for the unit.... Half the fun is looking right?
08-17-2008, 04:28 PM
Person County
, North Carolina
The same thing happened to my '05 25 Safari SS. The edges were lifting up on the toilet riser where the vinyl meets the wall. I installed some quarter round molding around all of the edges.
I came across that fix here on the site....I can't seem to put my finger on the link though.
08-31-2008, 12:47 AM
Salem
, Oregon
Bathroom floor lifting.
Hi, I would say that this was normal on models like mine and not caused by water leaks, but just not the best design on the bathroom floor area. I fixed my own with 1/4 round oak and aluminum trim. Click on pictures to enlarge them for better view.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-31-2008, 07:18 AM
Dexer
, Michigan
wow your modifications look great! Thank you for sharing. We may just wait and see if the asking price comes down a bit.
08-31-2008, 10:59 AM
2004 25' Classic
Prescott
We just bought a 2004 25 Classic with the same lifting of the vinyl around the wall by the toilet as kevino stated. What ROBERTSUNRUS did looks very good and I will be doing the same except maybe using an off white? trim as I have the light colored vinyl.
ROBERTSUNRUS, are the wood trim pieces glued or nailed down?
This is one awesome site!!
08-31-2008, 09:40 PM
Salem
, Oregon
Hi, RLS. I have a small air powered nail gun that I used to hold the 1/4 round oak mouldings in place. The aluminum strips on the top edge, in front of the toilet, were carpet strips that I cut narrower and then angle cut to fit in place and used screws to hold them down. Most of the holes were already there, but I made a few more make it fit better.
09-01-2008, 10:15 PM
2004 25' Classic
Prescott
ROBERTSUNRUS,
Thank you for the info. ~~
