Old 09-20-2014, 02:32 PM   #1
gomotomoto's Avatar
Longport , New Jersey
First post. First Airstream. Psyched! Stressed! Confused!!!
Hi All,
First airstream, first post
Just took the plunge on a ground up restoration -- a 1964 28' Airstream Ambassador. It sits complete at 4200lbs. Outfitted nicely with good brakes, solid frame, freshly packed bearings. Was restored by a capable auto mechanic as his own trailer.
Our tow vehicle is a 2003 Toyota Sequioa. 4.7 with a tow capacity of 6200lbs. Has the factory tow package and a transmission cooler.
So my first question is about an anti-sway and load distribution system. Do I put on a simple reese product, or do I go for something like the Hensley setup? Safety is my first concern as I'll be traveling with my family.
Our first trip will be from Orlando from NJ, so it's a big one.
Thank you and any insight is much appreciated.
gomotomoto is offline   Reply With Quote
Old 09-20-2014, 02:46 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Welcome to the club of AS ownership!
Hitches are like trucks, motorcycles, whiskey, PC's and the like. Everyone has a strong opinion as to why their hitch/laptop/truck/motorcycle is the best and the only one you should get!!
The brand of hitch you get is really immaterial so long as you stick with one of the major brands. Quite frankly, I would recommend that you base your brand-decision more on the availability of a qualified and responsive dealer in your area to help you set up the hitch for your particular trailer/tow vehicle combination rather than worry over Reese vs. Hensley vs. Blue Ox, etc..
You absolutely should get a weight distributing hitch with some anti-sway control, not just a plain old ball hitch. There are several good brands around and undoubtedly a number of forum members will post shortly to tell you that to buy any brand other than the one they own is akin to committing suicide!
Use the Search Function on this thread to find some of the past posts that deal with the issue of hitch selection. The Search Function is on the right side of the blue bar above the posts.
Happy hunting!
Bob Martel
WBCCI# 5766
Old 09-20-2014, 03:29 PM   #3
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
oh, and don't be stressed....you own an Airstream!
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 09-20-2014, 05:01 PM   #4
gomotomoto's Avatar
Going with the ProPride to be on the safe side. Spoke to the owner today and he was awesome. Very helpful.
Old 09-21-2014, 12:08 PM   #5
Chelsea , Michigan
Images: 12
I know a lot of people who use ProPride and love it. You've made a good choice. Now finish up your restoration so you can get out there and start using the Airstream!
Bob Martel
WBCCI# 5766
Old 09-21-2014, 12:13 PM   #6
Hi All,
A Reese dual cam, 600 pound full sway control hitch, would do a great job for you.
Old 09-21-2014, 12:34 PM   #7
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
We sure like our ProPride, very stable pull and easy to hitch. When we got our new 25 FC, we transferred it from previous rig. Enjoy!
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 09-21-2014, 01:07 PM   #8
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
While I do not have a Pro Pride, but a Reese, I am wondering if anyone has a link to a Pro Pride, I amy wish to change at some point, or add it to another trailer.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-21-2014, 01:09 PM   #9
dznf0g's Avatar
Oswego , Illinois
Trailer Sway Elimination | Sway Control | Truck RV Trailer Hitch Accessories | ProPride, Inc.
-Rich-
Old 09-21-2014, 01:18 PM   #10
Msmoto's Avatar
2007 25' Safari
Images: 135
@dznf0g
Thank you…. I guess by the time one has this installed it comes close to $3,000 correct?
AIR #31871 K4MTL
Old 09-21-2014, 01:22 PM   #11
Chelsea , Michigan
Images: 12
Originally Posted by Msmoto View Post
@dznf0g
Oh no. I don't recall the exact figure, but I believe that our Reese hitch setup cost just under $1,000 installed (including the hitch ball and mount.) I can't imagine that the very similar ProPride would be much more.
Bob Martel
WBCCI# 5766
Old 09-21-2014, 01:25 PM   #12
Msmoto's Avatar
2007 25' Safari
Images: 135
Yeah, my Reese was about $1,000. But the Pro Pride, is much more.
Trailer Sway Control Hitch Guaranteed to Eliminate Trailer Sway - ProPride 3P
AIR #31871 K4MTL
Old 09-21-2014, 01:54 PM   #13
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Hensley/ProPride uses a different method of handling sway forces projecting the movement to the truck's rear axle where it is eliminated, instead of leveraging it forward to the steering axle depending on friction or cams to dampen the forces.
Quite a remarkable difference in towing ease for the driver, with a safety component for the passengers.
Doug and Cheryl
Old 09-21-2014, 02:04 PM   #14
dznf0g's Avatar
Oswego , Illinois
gomotomoto, and just where are the pictures?
-Rich-
Stressed Noco Member Introductions 9 05-02-2013 06:22 PM
Looking for first new Airstream. Confused about what model to choose? hunter_rv Airstream Lifestyle 5 09-06-2012 06:33 AM
