Old 07-11-2011, 10:39 AM   #1
roadliner54's Avatar
1975 Argosy 20
Jensen Beach , Florida
Fan-Tastic Vent Fan
Awesome!!!! we send away are fan (hp40000btow)on 6.30.11 to have it repaired. we receive are new repair & refurbish fan on 7.6.11, that's just amazing "CUSTOMER SERVICE". thank you!!!
roadliner54 is offline   Reply With Quote
Old 07-11-2011, 11:05 AM   #2
1969 27' Overlander
Kimmell , Indiana
Yes Roadliner54. I called to order parts to repair a Fantastic vent/fan for my Newell and after I gave the lady my parts list she suggested I send it in to be rebuilt....What I recieved was a brand new fan!!!!awesome. Even though I can buy off-brand fans locally from RV warehouse salvage stores I will be installing FANTASTIC FANS!
Hoosierdaddy is offline   Reply With Quote
Old 07-11-2011, 11:14 AM   #3
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I actually installed 2 of these in my trailer. My 64 had a white dome in the rear, and a flat aluminum in the kitchen, so I chose models close to those. I have a couple comments. 1, they are fantastic. Quiet, and move a ton of air.
If you get the flat roof that VTS sells, the motor is a low profile - which means you can't see the motor when the vent is open. I like that look a lot. If you look at my trailer, if both vents are open, you can see the motor in the one that has the dome, but you can't see it in the one that is flat. I would have preferred they were both low profile motors just for the looks, but the traditional motor is just a little bit quieter.
Haven't needed the customer service, but I'm glad about the reputation. I've been running the fans pretty regular during the day to keep the heat in the trailer down. I also put bubble foil on the windows on the south side. Seems to help a lot.
robwok is offline   Reply With Quote
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Knob for kitchen exhaust vent fan chrischarles General Repair Forum 0 05-08-2011 06:53 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
Vent fan motor/blade Rickman4 Roof Vents, Skylights & Fans 0 01-27-2011 09:44 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 04:12 PM
