Old 03-04-2015, 08:43 AM   #1
2001 30' Excella
Lincoln , Michigan
Factory Brake Contol Warning
I have a 2005 Ford with the factory tow package option, and it worked well for some time, however, it is starting to display error messages (trailer fault/check wiring) and we have had the trailer power cord and the truck end replaced with no success.
Was wondering if anyone had this same situation? Is there a way to diagnose the controller on the tow vehicle?
Can a 12v coach battery if there is a defective cell in battery, for example) enter into this problem?
Would appreciate any input you may offer.
FSoper2378 is offline   Reply With Quote
Old 03-04-2015, 09:19 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Since it appears you have a trailer i would question the use of the word coach. Are you referring to your truck battery or trailer battery?
If the truck battery is in question I would test the voltage while the truck is off. If low just swap it out with a good battery for a test. It is hard to say what lower voltage might do to a piece of electronic gear like a controller.
2004 Excursion 4x4
Old 03-04-2015, 09:54 AM   #3
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Check your connections at the backing plates, insure the connections are secure.
jkcru is offline   Reply With Quote
Old 03-04-2015, 11:35 AM   #4
2002 30' Classic
Ocala , Florida
Check your trailer brake wiring to each trailer wheel, may be a pinched wire or a break somewhere. Other 2005 F250 owners with same problem traced cause to wires. Once repaired message no longer appeared.
Here is quote from Ford-trucks.com website "mine did the same thing it would say trailer fault whenever you hit the brakes and sometimes trailer disconnect but the lights would work fine and this was on a brand new trailer so I hooked a buddy of mine trailer up to it and it worked perfect so I traced my brake wires from the tongue back to the axles and found out that one of the wires had been pinched in half and the other was smashed inbetween the trailer floor and the side frame after I spliced the wires back together everything worked perfect"
Bigdaddy_2 is offline   Reply With Quote
Old 03-04-2015, 12:14 PM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Why question the use of the word coach?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-04-2015, 03:03 PM   #6
For the contects between the trailer and the truck I always spray both with WD40.
BillbB is offline   Reply With Quote
Old 03-04-2015, 04:53 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A coach can be either a motor home or a trailer, but a trailer is always a trailer.
Old 03-04-2015, 05:54 PM   #8
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Agree with the above posts about checking the wiring at the backing plates on the trailer wheels, I had a short in mine that caused this issue with the Ford IBC on my 2006 F250.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 03-04-2015, 11:59 PM   #9
1973 31' Sovereign
wolfforth , Texas
Would advise against wd 40 around wires. Know of a case where it cost a several thousand $$ set of aircraft radios. I am aware it is a water dispersant. (Sp). Would advise us of a good contact cleaner. Goodluck.
flingwingbob is offline   Reply With Quote
Old 03-05-2015, 11:12 AM   #10
Tupelo , Mississippi
Good customer of mine was having same problem with his 5th wheel. Finally traced it to the brake wire that Dexter had run through the axle tube. Over years of the wire bouncing around inside the axle tube, the insulation had worn away and was causing it to make contact with the inside of the axle tube, thereby creating more resistance which the brake controller read as a fault.
rvbsmart is offline   Reply With Quote
Old 03-08-2015, 05:17 PM   #11
Jarrod White's Avatar
1966 28' Ambassador
Mobile , Alabama
If the messages are appearing with trailer disconnected, the controller had probably gone bad. Fairly common problem I understand with 2005 model ( mine included). There is swap service for rebuilt one on eBay for $99 which I'm going to do soon (haven't gotten around to removing).
Jarrod White is offline   Reply With Quote
Old 10-03-2016, 12:56 PM   #12
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
I recently had the same problem with the connection from the trailer and the 7 pins extension connected to my Ram truck. It seems water entered the connections and caused a short which in turn showed as a brake disconnect . A little wd40 and liquid tape corrected the problem. It seems water migrated into the connection. The give away was the flickering of the connect notice on the dash.
Barbieri is offline   Reply With Quote
Old 10-04-2016, 08:54 PM   #13
2016 25' Flying Cloud
Holly Springs , Mississippi
Just had a very similar problem. Banner said "Wiring Fault on trailer." Also got a "Trailer disconnected" when it wasn't. It was the trailer controller module. Ford dealer charged $750 for a new one. If you can get a rebuilt one on eBay for $99, now that's a plan!
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 10-06-2016, 09:28 PM   #14
1966 28' Ambassador
Mobile , Alabama
I can report back that the $99 rebuild on eBay worked and resolved my controller problems.
Warning! Birchwood. Warning!!! austreampete Commercial Listings 1 01-10-2004 09:04 AM
