Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-14-2019, 05:52 PM   #1
2019 27' Tommy Bahama
Ocean Pines , Maryland
Electric Outlet
We have a Tommy Bahama Airstream and would like to use. A DynaTrao for bugs outside. Is there an electrical outlet on the outside of the AS as it requires electricity. Suggestions pls.
Docbutch is offline   Reply With Quote
Old 06-14-2019, 06:49 PM   #2
2018 19' Flying Cloud
Newport , Washington
Short answer is yes there is an outlet. Long answer is why don’t you go look on the trailer. It will be an outdoor type outlet so will have a cover over it.
KelloggKid is offline   Reply With Quote
Old 06-14-2019, 06:59 PM   #3
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
If you are doing this away from shore power you might need to check to make sure the outlet is an inverter outlet and also that your inverter can supply enough current.
daleyocum is offline   Reply With Quote
Old 06-15-2019, 05:44 AM   #4
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Yes, should be near your door or wheel well
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 06-20-2019, 09:20 AM   #5
2018 30' Classic
Jacksonville , Florida
Plug in the trailer to power if it needs it or use another method of bug control.
You asked us if your trailer has an outside outlet. I don't know. I can't see it from here.
Overstreet is offline   Reply With Quote
2004 Safari external electric outlet cover fwills General Repair Forum 0 11-03-2014 11:07 AM
Questions on replacing exterior outlet, reflector, & mystery electric socket dgreen78 Lights - Interior & Exterior 3 08-04-2014 12:17 PM
Electric fridge outlet Anton66 Refrigerators 4 11-14-2011 12:23 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
