Old 08-17-2004, 01:30 PM   #1
frozen chosen's Avatar
Elec. Compressor recommendations?
Any recommendations for a small compressor to fill tires and blow out water lines for winterization? There are several cheapies at Wallmart, but I imagine I can do better. I recall that the pressure to blow out water should be no more than 60PSI, which would seem to be a problem if I also want to inflate tires. Doesn't have to be 12V, as I will not be taking it with us. Thanks for any help.
frozen chosen is offline   Reply With Quote
Old 08-17-2004, 01:33 PM   #2
I used the local gas station's free air pump. Boy, do I feel cheap. LOL
Rick
Rick Alston is offline   Reply With Quote
Old 08-17-2004, 01:54 PM   #3
You can regulate the output air pressure - they don't have to work at maximum pressure. For blowing out water lines you want air volume. Five gallon tank, at least, and a 5 hp motor would be good. But I didn't do that.
I bought a Deltal oil-less compressor - http://www.deltawoodworking.com/index.asp?e=136&p=4722 . It will inflate the tires and, being oil-less it will not introduce traces of oil into the water lines. I got it at Lowe's for, I believe, $89 a year or so ago.
HOWEVER, its chief attraction for me is that it will store away under the wardrobe floor in the trailer. That way, I can blow out the lines at a campsite (or top off tires) before returning home in freezing weather. If I was not going to carry it with me I'd want something with a larger tank for blowing out water lines. It does the job, but slowly.
Oil-less compressors are somewhat loud. If you want a quieter oil type you can get the filters made to keep oil out of paint guns and so forth.
Mark
Old 08-17-2004, 02:02 PM   #4
aluminauts's Avatar
vancouver , Washington
I am pleased with our choice of the 2hp 120v sears unit.
see this thread post # 8 on:
http://www.airforums.com/forum...ead.php?t=9333
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
aluminauts is offline   Reply With Quote
Old 08-17-2004, 03:18 PM   #5
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
I'm pleased with my little 2 gallon 120V Husky ... purchased from Home Depot for $89.00 ... probably the same unit as the Sears.
I just store it in the bed of my F-350 ... small and quiet ... great for inflating my truck and trailer tires before I hit the road.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 08-17-2004, 05:58 PM   #6
LOST , Hawaii
I am not a real fan of Sears power tools but got a 1 1/2 hp for $100. 2.4 cfm at 90 psi (probably on the low end for blowing out water lines), cast iron cylinder liner. It is small enough so I mounted it in a storage compartment, 125 psi so I can fill tires without taking forever.
John
74Argosy24MH is offline   Reply With Quote
Old 08-17-2004, 07:20 PM   #7
Cracker's Avatar
Pittsfield , Maine
I mounted a Sears 120 volt, oil-filled air compressor, with a 2-gal tank, just behind the right, rear wheel well in the truck bed. It fit the recess nicely, with minor modifications and re-piping of the discharge and gauges, without restricting the 4 foot bed width. I carry two Honda 2KW generators with me on 4 foot wide roll-out platform. This provides more than adequate air for maintaining the tires on the dually and the trailer, using two of the +/- 20' coiled lengths of air hose, coupled together. To my surprise, however, the compressor needs to have both generators running and hooked up in parallel! This isn't a problem - since I have the correct parallel cable hookup - but I would have sworn that one generator would have been adequate before I tried it!
Cracker
Cracker is offline   Reply With Quote
Old 08-17-2004, 08:20 PM   #8
Tinsel Loaf's Avatar
I have two small 12 volt heavy duty compressors tied together to a one and a half gallon tank mounted under the van. The compressors charge the tank to 110 psi and operate the air shocks and the pac brake on the van. I have put air fittings on both sides of the van and one inside to make an air hose connection if I need it. You can get quite a good short hi volume blast of air when needed to clean things off and keep your tires inflated.
Tinsel Loaf is offline   Reply With Quote
Elec. problem again! davidz71 Electrical - Systems, Generators, Batteries & Solar 48 03-13-2005 05:37 PM
One Elec Brake not Equal to Other Three wingfoot321 Brakes & Brake Controllers 1 04-24-2004 03:01 AM
elec woes joel Electrical - Systems, Generators, Batteries & Solar 2 09-11-2003 06:49 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
testing the elec brakes? Rog0525 Brakes & Brake Controllers 3 06-11-2002 03:02 PM
