Old 05-21-2014, 11:00 PM   #15
This is something I was thinking about too, and only someone with experience could answer. Is the insulation on a 2014 that much more superior that a single 15k btu AC would be sufficient in Las Vegas heat (in the shade)?
jamesk is offline   Reply With Quote
Old 05-21-2014, 11:04 PM   #16
1974 Argosy 20
Kooskia , Idaho
I believe the insulation is better but I really have no idea if the 15 k unit, in the shade, in LV would be enough or not. Some people want it 70-72 no matter what, some can be happy with it considerably warmer. I don't think there is a one size fits all answer possible for you.
Old 05-22-2014, 04:58 AM   #17
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
My point was that this is a fairly straightforward installation one could do himself saving a heap of cash.
AtomicNo13 is online now   Reply With Quote
Old 05-22-2014, 05:43 AM   #18
Gainesville , Florida
I have used portable units with good results. Yes you need an exhaust hole and the units take up space, but it will plug into a standard outlet and does not pull yoo many amps. I used mine in a truck camper. Get the kind that does not need a drain. Jim
Old 05-22-2014, 05:44 AM   #19
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
We had a white box trailer with one a/c.
Our Airstream has 2.
The trailers with one a/c are 30 amp trailers.
The trailers with 2 a/c's are 50 amp trailers.
There are other benefits to a 50 amp trailer with 2 a/c's.
The microwave or a hair dryer will often trip the breaker in a 30 amp trailer with the a/c running. It is inconvenient to turn off the a/c to make popcorn or for the wife to blow dry her hair.
With 2 a/c's, 2 people can have different temperature zones. My wife is always burning up and I am always freezing.
The only downside to a 50 amp trailer is the bigger, heavier shore cord.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-22-2014, 06:12 AM   #20
Skater's Avatar
1995 30' Excella
Bowie , Maryland
If I were buying a new (longish) trailer, I'd definitely get two A/Cs. Our 30' doesn't do well getting cool air back to the bedroom with just one A/C if the doors are closed (there's an opening above the doors for this purpose but it has limited value).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-22-2014, 06:31 AM   #21
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I added the 2d A/C to my 28' last summer. 'Nuff said.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-23-2014, 04:42 PM   #22
2014 28' International
2008 27' International FB
Sonoma , California
Get two. In the CA foothills, our 27 cannot keep up with the 95-100 degree heat at all with just the single unit.
ramblin rose is offline   Reply With Quote
Old 08-23-2014, 09:26 PM   #23
megandrudy's Avatar
2011 34' Classic
Sebring , Florida
Go for dual A/C. You won't be sorry.
David, Debbie, Jenna-Leigh
and our 2 dogs....
Meg and Rudy!
megandrudy is offline   Reply With Quote
Old 08-24-2014, 02:33 AM   #24
m.hony's Avatar
2013 30' Classic
It's more than getting a second a/c.
It is getting a 50 amp trailer instead of a 30 amp trailer.
Now, you can use the a/c and the microwave or a hair dryer at the same time without tripping a breaker.
I will never ever never have a 30 amp trailer again!
Regardless of which brand of trailer purchased, this is one piece of advice I wish everyone shopping for any RV trailer or motorhome would hear me out on-
TAC #MS-10
Airforums #70955
Old 08-24-2014, 03:31 AM   #25
JFScheck's Avatar
Rockville , Maryland
Images: 33
27 or larger and you need that second A/C unit!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 08-24-2014, 03:33 AM   #26
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
"Adding" 50 amp and second AC are not trivial to do at home. It is far better to have AS Factory install.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-24-2014, 03:54 AM   #27
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Images: 135
In a newer unit, the cost of the second A/C will return itself at resale. And even in my 2009 27 FB International one A/C would not keep it below 80 degrees in almost any southern venue in the US.
The 50 Amp cord.... well at age 72 I handle this by simply being careful and not attempting to lift the entire cord at once. Maybe a minute or two more work, but the convenience of not having breakers trip, especially if one has an espresso machine, hair dryer, etc, which might do this in a 30 amp, more than makes up for the slight bit of work dragging the big cord around.
And, there is really no extra space in a trailer for a portable A/C unit, and this does not sound like good advice.....especially in a new purchase.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-24-2014, 05:42 AM   #28
m.hony's Avatar
2013 30' Classic
The benefits of a 60 amp trailer far outweigh the one down side- that big ole heavy, unruly black snake-
He is even stiffer and harder to handle in the cooler months-
TAC #MS-10
Airforums #70955
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
Univolt/Dual Batteries uwe Batteries, Univolts, Converters & Inverters 4 06-28-2002 08:26 PM
