Old 10-23-2017, 05:01 PM   #1
ExStreamin's Avatar
2014 30' International
Ellicott City , Maryland
Dometic refrigerator drain hose clogged
Has anyone had an issue with the Dometic refrigerator drain hose clogging? When the refrigerator is running, every few hours I will hear a noise from beneath it that sounds like a pump. Then water appears under the fridge. I believe the drain hose is clogged but it looks fine from the outside access panel. Any ideas how to access the hose from the inside? Our trailer is a 30 ft International.
2014 International Serenity 30'
Hensley Arrow hitch
Tow Vehicle: 2001 Ford Excursion 7.3L Diesel
ExStreamin is offline   Reply With Quote
Old 10-23-2017, 09:10 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Hmmmmmm... clogged? Or is the tube disconnected?
Time to pull the fridge and check. 4 screws.... (2 Phillips #3 front side at the bottom, accessed from inside the trailer and 2 lag bolts in the rear, accessed from the exterior access panel door) ....and she slides right out.
Its the only way to access the rear of the fridge to check the drain hose connection......
wulfraat is online now   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
Clogged Shower Drain on MH comprose Plumbing - Systems & Fixtures 4 09-18-2015 03:05 PM
Broken or clogged A/C drain line danjoe91 General Repair Forum 5 05-13-2013 09:01 PM
Solved: Air Conditioning Drip Hose Clogged TankerIP Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-23-2010 09:05 AM
Help! Yucky clogged shower drain Blu_Hwy_Lady Waste Systems, Tanks & Totes 25 05-10-2006 01:07 PM
