Old 12-22-2015, 01:25 PM   #1
benicia , California
Dometic fridge not cooling down on LP
I started a thread in General Repair but I don't think it's getting enough eyes on it so was hoping to get some responses thru this forum.
Not sure what I am doing wrong but my fridge doesn't cool when using LP. I've left the setting on LP for at least a couple of hours but the temp stayed at 60 degrees F. I have to switch it to Auto in order to cool my fridge. I just don't think LP is getting to the fridge. The water heater and furnace works just fine.
I've owned my 2011 28' FC for a little over a year now and this fridge issue has been with me ever since. One time, I let it "run" on LP overnight and it never cooled down so I switched to Auto. Luckily, in the two times I boondocked, I've had plenty of ice in the Igloo cooler to keep food fresh.
Is there a way to check if my fridge is getting LP? Thanks!
cantdrv55 is offline   Reply With Quote
Old 12-22-2015, 02:05 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I assume your pilot light us lighting, correct?. ..... Mine would not cool well on gas. It was caused by low LP pressure. Fortunately, my camper has an inline LP pressure gauge at the LP line hookup at the back of the fridge. I adjusted my regulator and it worked fine....Another thing to check is to see if the flue is dirty or clogged.
CRH is offline   Reply With Quote
Old 12-22-2015, 02:26 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
When you turn the fridge onto LP do you hear the system clicking at the outside fridge vent near the burner? That is the sound it make when its trying to ignite the burner. It will try for about a minute then wait to try again later. You can turn the fridge off/on to LP to restart the sequence. Can you run the stove top LP burners OK?
Hot water heater run on LP OK?
Kelvin
Old 12-22-2015, 02:31 PM   #4
The stove and oven works fine as does the hot water heater and furnace. I do hear a click when I switch from Auto to LP. There is a burner for the fridge? is it outside the camper you say?
Old 12-22-2015, 02:34 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
It has a pilot light. Open fridge access panel outside trailer and you can see where the gas line goes to the burner. Feel and see if that area and the flue pipe are warm.....Does your fridge panel nit have a "check" light?
Old 12-22-2015, 02:50 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
The modern gas/absorption fridges like that of the OP DO NOT have a pilot light. They are DSI controlled (direct spark ignition). If you can hear the igniter clicking, it may not be getting LP.
Two possibilities. The gas valve is not opening ( brass solenoid in the LP line with 2 wires coming from it) or the igniter is out of position at the burner.
I would look at the latter first. You also might have insect infestation in the LP feed line between the solenoid and the burner, or rust might be blocking the burner vents.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 12-22-2015, 02:56 PM   #7
KJRitchie's Avatar
2008 25' Classic
The burner at the bottom of the fridge flue isn't like the one for the water heater that makes a tremendous roar when lit. The fridge burner looks like a pilot light but its enough to heat up the cooling tube at the bottom of the burner. There is sheet metal enclosing the burner. You can hear a slight sound of the burner when its lit if you stick your head into the vent. You can easily see if the burner is lit when it is darker. You should see a blue flame. Verify the electronic ignition is trying to light the burner, that is the clicking sound. Works similar to the stove top ignition. It generates a spark to ignite the LP. If its clicking but no flame then the LP is not getting to the burner. Could be the circuit board then or the LP jet is plugged up. If you hear the clicking but the flame doesn't light then it may be best to take it in to an RV repair to have them check the fridge LP system. These fridges aren't Airstream specific.
Kelvin
Old 12-22-2015, 03:29 PM   #8
Is the fridge flue inside the trailer or outside? Thanks.
Old 12-22-2015, 03:57 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
The flue is at the back. You access it outside the trailer.
Old 12-22-2015, 03:59 PM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
Lewster, you of course are correct...by pilot light I was referring to the burner, which should put off heat he can feel. My bad on the incorrect terminology.
Old 12-22-2015, 07:04 PM   #11
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
To familiarize yourself with the working parts of your refrigerator you could do the following:
Using the refrigerator's model number and the Internet look up either owner's manual or parts. The online parts seller have exploded view drawings that label the parts for you. The owner's manual may show the layout to where all the parts are your friendly forum members have been posting for you.
One things that has been mentioned already the refrigerator needs to be hot; as seen from the outside of the trailer when you open the access door. Either the propane burner or the electric heater will be the heat source.
Good Luck,
sgschwend is offline   Reply With Quote
Old 12-22-2015, 07:13 PM   #12
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would not recommend trying to debug this unless you are very sure of yourself. There are too many ways this can go way wrong. The fridge should work on LP just about as well as on shore power so if you are having issues with LP but not shore power then the easy issues such as leveling and airflow do not apply. I would get a Dometic (or Norcold as the case may be) certified tech involved in debugging and fixing this issue.
Bob Martel
WBCCI# 5766
Old 12-22-2015, 10:47 PM   #13
Great advice everyone. Thank you.
Old 12-23-2015, 10:25 AM   #14
1996 25' Excella
Tillsonburg , Ontario
If your fridge doesn't show the "check" light, then the flame is on. Your flue is likely plugged so heat is not getting up the stack to warm the evaporator coils. The electric heater will warm the gas coils even if the flue is plugged.
You may need to go to a dealer for service since the disassembly of the flue is beyond most owners.
JCW
JCWDCW is offline   Reply With Quote
A.c. Not cooling, I don't hear compressor engage when I turn up or down. Summer's com jimin pa All Argosy Trailers 2 05-07-2015 02:54 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Dometic fridge cooling unit Jim & Susan Refrigerators 19 09-03-2013 12:40 PM
noob fridge ? :cooling down TINLOVE Refrigerators 13 10-16-2010 02:16 AM
'09 Classic - fridge not cooling woppa 4 Refrigerators 18 05-18-2009 05:32 PM
